DS18B20 With variable target
Hello to all,
I would like to implement a variable control with a DS18B20 temp sensor. Either using a potentiometer on an analog pin or using two buttons to change the target temperature up or down.
See below a simple sketch with this fixed parameter. if (temperature > 19)
This project controls my electrical geyser. Currently if I need to change the target temperature, "occasionally" then I need to connect the USB cable to the device and modify the, if (temperature > 19) to if (temperature > 20).
Any one able to figure this out?
I have completed a similar project that works over the internet and I would like to implement the same idea.
Regards
#define RELAY1  9
#include <OneWire.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
OneWire ds(12);
void setup(void) {
  pinMode(RELAY1, OUTPUT);
  lcd.begin(20, 4);
  float temperature = getTemp();
  lcd.print("   TEMP - STATUS  ");
void loop(void) {
  Serial.println(temperature);
  lcd.setCursor(0, 1);
  lcd.print(temperature);
  if (temperature > 19) {
    digitalWrite(9, LOW);
    lcd.print("     Geyser OFF");
    digitalWrite(9, HIGH);
    lcd.print("      Geyser ON");
float getTemp() {
  byte data[12];
  byte addr[8];
  if ( !ds.search(addr)) {
    ds.reset_search();
    return -1000;
  if ( OneWire::crc8( addr, 7) != addr[7]) {
    Serial.println("CRC is not valid!");
    return -1000;
  if ( addr[0] != 0x10 && addr[0] != 0x28) {
    Serial.println("Device is not a DS18x20 family device.");
    return -1000;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);
  byte present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);
  for (int i = 0; i < 9; i++) {
    data[i] = ds.read();
  ds.reset_search();
  byte MSB = data[1];
  byte LSB = data[0];
  float tempRead = ((MSB << 8) | LSB);
  float TemperatureSum = tempRead / 16;
  return TemperatureSum;
moderator: added code tags ==> # button above smiley's
using a potmeter is relative simple
find the 7 differences
#define RELAY1  9
OneWire ds(12);
void setup(void)
  lcd.begin(20, 4);
  lcd.setCursor(0, 0);
  lcd.print(" TEMP - STATUS - TH ");
void loop(void)
  // GET CONFIG
  int raw = analogRead(A0);
  int threshold = map(raw, 0, 1023, 5, 30);
  lcd.setCursor(14, 1);
  lcd.print(threshold);
  // GET TEMPERATURE
  lcd.print(temperature, 1);
  // ACTION
  if (temperature > threshold)
    digitalWrite(RELAY1, LOW);
    lcd.setCursor(7, 1);
    lcd.print("G-OFF");
  if (temperature < threshold - 1) // prevents hysteresis
    digitalWrite(RELAY1, HIGH);
    lcd.print("G-ON");
float getTemp() {
  byte data[12];
  byte addr[8];
    ds.reset_search();
    return -1000;
    return -1000;
    return -1000;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);
  ds.select(addr);
  ds.write(0xBE);
  ds.reset_search();
  byte MSB = data[1];
  byte LSB = data[0];
Thanks
robtillaart
I appreciate you help. You are a Star.
Regards
