(I had no 4.7K and put 2 10K parallel, actual value is below 5K)
Code:
#include <OneWire.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
void loop(void) {
float temperature = getTemp();
Serial.println(temperature);
delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
void setup(void) {
void loop(void) {
float getTemp(){
byte data[12];
byte addr[8];
ds.reset_search();
return -1000;
Serial.print("CRC is not valid!\n");
return -1000;
return -1000;
ds.reset();
ds.select(addr);
ds.select(addr);
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float CONT_REMAIN = data[6];
float CONT_PER_C = data[7];
TemperatureSum = tempRead/2-0.25+(CONT_PER_C-CONT_REMAIN)/CONT_PER_C;
It said: I had to change the code at the end, a bracket was left off, as was the tempSum type
I can see that one } is missing, but where to place it, and how to set the tempSum type?
So typical, people ask first before using some common sense… pathetic… This works perfectly:
The circuit diagram you link to shows the DS18S20 wired in non-parasitic mode but your code requests the temperature in parasitic mode. If the code and the wiring aren't consistent the readings you get may not be reliable.
