I have two sensors (same type) and I want to compare the temperatures ,in order to activate 2 different motors ,depending on which temperature is higher.
If "temperature 1 " is higher than "temperature 2" I want to start "motor 1" .If "temperature 2 " is higher than "temperature 1" I want to start "motor 2"
The sensors are working on the same bus ,and so far I've managed to check the temperatures with this scetch,but I don't know how to compare the temperature values in digital sensors
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
// locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// assign address manually. the addresses below will beed to be changed
// to valid device addresses on your bus. device address can be retrieved
// by using either oneWire.search(deviceAddress) or individually via
// sensors.getAddress(deviceAddress, index)
//insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
//outsideThermometer = { 0x28, 0x3F, 0x1C, 0x31, 0x2, 0x0, 0x0, 0x2 };
// search for devices on the bus and assign based on an index. ideally,
// you would do this to initially discover addresses on the bus and then
// use those addresses and manually assign them (see above) once you know
// the devices on your bus (and assuming they don't change).
// method 1: by index
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
// method 2: search()
// search() looks for the next device. Returns 1 if a new address has been
// returned. A zero might mean that the bus is shorted, there are no devices,
// or you have already retrieved all of them. It might be a good idea to
// check the CRC to make sure you didn't get garbage. The order is
// deterministic. You will always get the same devices in the same order
// Must be called before search()
//oneWire.reset_search();
// assigns the first address found to insideThermometer
//if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
// assigns the seconds address found to outsideThermometer
//if (!oneWire.search(outsideThermometer)) Serial.println("Unable to find address for outsideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
Serial.print("Device 1 Address: ");
printAddress(outsideThermometer);
// set the resolution to 9 bit
sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
Serial.print("Device 1 Resolution: ");
Serial.print(sensors.getResolution(outsideThermometer), DEC);
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
// zero pad the address if necessary
if (deviceAddress < 16) Serial.print("0");
_ Serial.print(deviceAddress*, HEX);_
_ }_
_}_
_// function to print the temperature for a device*_
void printTemperature(DeviceAddress deviceAddress)
* float tempC = sensors.getTempC(deviceAddress);*
* Serial.print("Temp C: ");*
* Serial.print(tempC);*
* Serial.print(" Temp F: ");*
* Serial.print(DallasTemperature::toFahrenheit(tempC));*
// function to print a device's resolution
void printResolution(DeviceAddress deviceAddress)
* Serial.print("Resolution: ");*
* Serial.print(sensors.getResolution(deviceAddress));*
* Serial.println(); *
// main function to print information about a device
void printData(DeviceAddress deviceAddress)
* Serial.print("Device Address: ");*
* printAddress(deviceAddress);*
* Serial.print(" ");*
* printTemperature(deviceAddress);*
* Serial.println();*
void loop(void)
* // call sensors.requestTemperatures() to issue a global temperature*
* // request to all devices on the bus*
* Serial.print("Requesting temperatures...");*
* sensors.requestTemperatures();*
* Serial.println("DONE");*
* // print the device information*
* printData(insideThermometer);*
* printData(outsideThermometer);*
Thanx in advance!
