DS2408 onewire plantage compilation
Hello,
i try to use A Onewire DS2408
A sujet was started by Janosik @Janosik , but the sujet was close. and when i tried to compile then crash.
i try also to use A Onewire DS2408 exemple and compilation crash also.
je want just interrupt on the ds2408.
I'm french then sypa with my english
i use a esp32 with ds2408?
can you help me ?
thanks
#include <DS2408.h>
#include <OneWire.h>
DS2408 ds(34);
Devices devices;
void setup(){
  ds.find(&devices);
void loop(){
  uint8_t readByte=ds.get_state(devices[0]);
  int pins=0;
  for(int i=0;i<4;i++){
    int readBit=bitRead(readByte,i);
    bitWrite(pins,i,1);
    bitWrite(pins,i+4,readBit);
  ds.set_state(devices[0],pins);
  delay(100);
and the error message:
Arduino : 1.8.12 (Windows 10), Carte : "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 115200, Core 1, Core 1, None, Disabled"
In file included from C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub.h:22,
                 from C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireItem.h:4,
                 from C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\DS18B20.h:11,
                 from C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\DS18B20.cpp:1:
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h: At global scope:
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:27:59: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_RESET_TIMEOUT        = {  5000_us };        // for not hanging to long in reset-detection, lower value is better for more responsive applications, but can miss resets
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:28:60: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_RESET_MIN[2]         = {   430_us, 48_us }; // should be 480
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:28:68: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:29:60: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_RESET_MAX[2]         = {   960_us, 80_us }; // from ds2413
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:29:68: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:32:61: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_PRESENCE_TIMEOUT     = {    20_us };        // probe measures 25us, duration of high state between reset and presence
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:33:60: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_PRESENCE_MIN[2]      = {   160_us,  8_us }; // was 125
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:33:69: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:34:60: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_PRESENCE_MAX[2]      = {   480_us, 32_us }; // should be 280, was 480
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:34:68: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:37:58: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_MSG_HIGH_TIMEOUT     = { 15000_us };        // there can be these inactive / high timeperiods after reset / presence, this value defines the timeout for these
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:38:60: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_SLOT_MAX[2]          = {   135_us, 30_us }; // should be 120, measured from falling edge to next falling edge
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:38:68: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:41:61: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_READ_MIN[2]          = {    20_us,  4_us }; // should be 15, was 30, says when it is safe to read a valid bit
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:41:69: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:42:61: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_READ_MAX[2]          = {    60_us, 10_us }; // low states (zeros) of a master should not exceed this time in a slot
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:42:68: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:43:61: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
 constexpr timeOW_t ONEWIRE_TIME_WRITE_ZERO[2]        = {    30_us,  8_us }; // the hub holds a zero for this long
C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub\src\OneWireHub_config.h:43:69: error: 'constexpr timeOW_t operator""_us(long long unsigned int)' called in a constant expression
Utilisation de la bibliothèque OneWireHub version 2.2.3 dans le dossier: C:\Users\Didier SSD\Documents\Arduino\libraries\OneWireHub
Utilisation de la bibliothèque OneWire version 2.3.7 dans le dossier: C:\Users\Didier SSD\Documents\Arduino\libraries\OneWire
exit status 1
Erreur de compilation pour la carte ESP32 Dev Module
and the source : GitHub - orgua/OneWireHub: OneWire slave device emulator
thanks
Didier
first read: "How to get the best out of this forum"
the redo your post putting the code between the </> tags
then.....
post the "DS2408.h" and the link "OneWire.h" that you are using.
Does the crash display any error messages?
If so, using the </> tags, post the error msgs.
