Hi Group,
For my pan/tilt project I am using two DS3120 servo's and the PCA9685 controller. and using the HCPCA9685 libray
Using the HCPCA9685.Servo(servo, Pos) command,
Servo is easy, a number from 0-15, but Pos is mory tricky. The question is how do I calculate the correct value for a position between 0 and 180 degrees movement/
Thanks foor your comments
map(percentage,0,100,0,180);
Since the default range of values for pos are 0 - 480 then maybe what you need is
pos = map(angle, 0, 180, 0, 480)
Unless your invisible code modifies the default range or isn't working with an angle, in which case it's over to you.
Steve
I would do a practical examination with the standard servo-library to find out:
what is the minum pulsewidth in microseconds
and the maximum pulsewidth in microseconds
The technical specs
https://de.aliexpress.com/item/32830538932.html
say pulsewidth range 500-2500us
the standard-range is 1000 µsec to 2000 µsec
some weeks ago I had a servo which was able to turn 180 degrees but only If I enlarged the pulsewidth range from the standard 1000 µsec to 2000 µsec
to go beyond the standard-range with 750 µsec to 2400 µsec
best regards Stefan
So I have rewritten my code to include the map statement.
The first part moves the lever from 0 to the max
#include <HCPCA9685.h>
#define I2CAdd 0x40
HCPCA9685 HCPCA9685(I2CAdd);
#define servoMin 0
#define servoMax 180
HCPCA9685.Init(SERVO_MODE); /* Wake the device up */
HCPCA9685.Sleep(false);
Serial.begin(9600); // Start Communication
HCPCA9685.Servo(2, 0); // move servo to 0 degrees
delay(25); // wait some time (its in all examples
for (float deg = servoMin; deg <= servoMax; deg = deg += 0.1) {
// unsigned int nmap = map(deg, servoMin, servoMax, 0, 480);
// HCPCA9685.Servo(2, nmap);
Serial.print(deg); // printit on the stdout
Serial.print(" - ");
// Serial.println(nmap);
delay(10);
// unsigned int nmap = map(90, servoMin, servoMax, 0+45, 480-45);
But the last command should place the lever at the 90degrees position but its way off.
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
- press Ctrl-T for autoformatting your code
- do a rightclick with the mouse and choose "copy for forum"
- paste clipboard into write-window of a posting
click on the pencil Icon to actiavte edit-mode of your posting.
then delete the pure text and do the three steps like described above
best regards Stefan
No idea where slipstick has taken the range 0,480 from.
The PCA9685-Chip has 12 Bit resolution which is 4096
Anyway "way off" is a much too unprecise description of what is happening.
It should be 90 degrees. How many degrees do you get with the code above?
but maybe it is this
deg = deg += 0.1;
This is a mixture between
deg = deg + 0.1;
and
deg += 0.1;
best regards Stefan
https://forum.hobbycomponents.com/viewtopic.php?t=2034
plus examples using values from that range. Of course it could be an error in the library documentation. I've never used that library myself.
Steve
Hello Stefan,
I tried to do that but wiht no result. Its a simple procedure, I know, but it dit no work for me.
You are working on an informatic project. And what is most needed in an informatic project is information.
You tried what to do?
and what was the result?
best regards Stefan
