DS3231 +- 3º grados
Hola a todos,
he creado un termómetro con DS32231 y la temperatura comprobándola con varios termómetros marca 3º de de más ¿cómo podría corregir ese desfase? ¿Se puede hacer por código.
Adjunto foto del montaje y código
Un saludo.
#include  <Adafruit_ST7735.h>
#include  <Adafruit_GFX.h>
#include <Wire.h>
#include "Sodaq_DS3231.h"
#include  <SPI.h>
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8
#define TFT_SCLK 13
#define TFT_MOSI 11
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
float maxTemperature=0;
float minTemperature=200;
char charMinTemperature[10];
char charMaxTemperature[10];
char timeChar[100];
char dateChar[50];
char temperatureChar[10];
float temperature = 0;
float previousTemperature = 0;
String dateString;
int minuteNow=0;
int minutePrevious=0;
void setup ()
   tft.initR(INITR_BLACKTAB);
   tft.fillScreen(ST7735_BLACK);
   Serial.begin(57600);
   Wire.begin();
   rtc.begin();
   printText("TEMPERATURA", ST7735_GREEN,30,65,1);  // Temperature Static Text
   printText("MAX", ST7735_RED,18,130,1);
   printText("MIN", ST7735_BLUE,95,130,1);
   //setRTCTime();
uint32_t old_ts;
void loop ()
 float temperature = rtc.getTemperature();
 DateTime now = rtc.now(); //get the current date-time
 uint32_t ts = now.getEpoch();
   if (old_ts == 0 || old_ts != ts) {
old_ts = ts;
 minuteNow = now.minute();
 if(minuteNow!=minutePrevious)
   dateString = getDayOfWeek(now.dayOfWeek())+", ";
   dateString = dateString+String(now.date())+"/"+String(now.month());
   dateString= dateString+"/"+ String(now.year());
   minutePrevious = minuteNow;
   String hours = String(now.hour());
   if(now.minute()<10)
     hours = hours+":0"+String(now.minute());
   }else
     hours = hours+":"+String(now.minute());
   hours.toCharArray(timeChar,100);
   tft.fillRect(10,0,160,65,ST7735_BLACK);
   printText(timeChar, ST7735_WHITE,20,25,3);
   dateString.toCharArray(dateChar,50);
   printText(dateChar, ST7735_GREEN,8,5,1);
 if(temperature != previousTemperature)
   previousTemperature = temperature;
   String temperatureString = String(temperature,1);
   temperatureString.toCharArray(temperatureChar,10);
   tft.fillRect(10,80,128,30,ST7735_BLACK);
   printText(temperatureChar, ST7735_WHITE,10,80,3);
   printText("o", ST7735_WHITE,90,75,2);
   printText("C", ST7735_WHITE,105,80,3);
if(temperature>maxTemperature)
     maxTemperature = temperature;
     dtostrf(maxTemperature,5, 1, charMaxTemperature);
     tft.fillRect(3,142,33,20,ST7735_BLACK);
     printText(charMaxTemperature, ST7735_WHITE,3,145,1);
     printText("o", ST7735_WHITE,35,140,1);
     printText("C", ST7735_WHITE,41,145,1);
if(temperature  < minTemperature)
     minTemperature = temperature;
     dtostrf(minTemperature,5, 1, charMinTemperature);
     tft.fillRect(75,140,36,18,ST7735_BLACK);
     printText(charMinTemperature, ST7735_WHITE,80,145,1);
     printText("o", ST7735_WHITE,112,140,1);
     printText("C", ST7735_WHITE,118,145,1);
void setRTCTime()
 DateTime dt(2015, 8, 27, 9, 35, 30, 4); // Year, Month, Day, Hour, Minutes, Seconds, Day of Week
 rtc.setDateTime(dt); //Adjust date-time as defined 'dt' above
}void printText(char *text, uint16_t color, int x, int y,int textSize)
 tft.setCursor(x, y);
 tft.setTextColor(color);
 tft.setTextSize(textSize);
 tft.setTextWrap(true);
 tft.print(text);
String getDayOfWeek(int i)
 switch(i)
   case 1: return "Lunes";break;
   case 2: return "martes";break;
   case 3: return "Miercoles";break;
   case 4: return "Jueves";break;
   case 5: return "Viernes";break;
   case 6: return "Sabado";break;
   case 7: return "Domingo";break;
  default: return "Viernes";break;
Hola y bienvenido al foro.
Te invito a que te leas las NORMAS, a fin de que aprendas a postear correctamente tanto código, como imagenes, enlaces, errores, etc.
Hola mi chavo, buen día.
Bueno hay varias cosas:
1.- puede ser el el VCC que este bajón 2.- tienes que revisar tu librería, puede ser que es te este afectando (en la parte de las matemáticas) 3.- si la diferencia es 3° pero es constante es decir, 3° en todas las temperaturas, lo que necesitas es hacer un ajuste en el software, puedes usar una función de Arduino o simplemente puedes intentar restarlos antes de presentar la temperatura. 4.- veo que tu funcion esta en el loop y esta "muy rapida" el sensor da un maximo de 1 lectura por segundo, si tu loop es mas rapido que eso vas a tener problemas.
una manera de arreglar eso, es poner un "softdeay".
De manera que tomes la temperature cada X tiempo, por ejemplo cada 2 o 3 segundos.
Otra cuestión es que no estas haciendo un "promedio" es normal que los sensores suban, o bajen rápidamente por cuestiones inherentes a la realidad.
Por qui en el Foro @Surbyte ha mostrado la técnica de promedio móvil. Te recomiendo que la busques... algo asi;
pseudocodigo;
incio de funcion de toma de temperatura// 1.- tomo tiempo 2.- si el tiempo se cumple 3.- tomo la temperatura 4.- la promedio 5.- el nuevo promedio es la nueva temperatura 6.- fin de la subfuncion de temperatura//
espero haberte ayudado.
-Alex.
El sensor da el valor interno del chip ds3231. Esto es usado para compensar la derivación del reloj por temperatura. La temperatura interna del chip es más alto, claro, esta trabajando, que la temperatura del entorno. Además influye la frecuencia de la demanda de temperatura y tiempo. Cada demanda significa trabajo para el chip y esto hace subir la temperatura interna.
