DS3231 - External VCC Connected but no alarm . Please Help!!!
I want to use DS3231 Alarm to turn on the Latch circuit so I can then turn on other circuitry.
I can get alarm working when connected to Arduino over SCL SDA. but after I set alarm and disconnect the ds3231 from arduino with external VCC it do not work. why?
I know Alarm do not work alone on coin cell Battery so I have provided 5V external VCC but still it do not work. isn't the alarm I set is burn inside the clock memory? why it is not triggering also what is the default duration of trigger?
below is the code I am using. please help.
#include <DS3231_Simple.h>
DS3231_Simple Clock;
  Clock.begin();
  // We will set 2 alarms, the first alarm will fire at the 30th second of every minute
  //  and the second alarm will fire every minute (at the 0th second)
  // First we will disable any existing alarms
  Clock.disableAlarms();
  // Get an initialized timestamp
  DateTime MyTimestamp = Clock.read();
  // We want the alarm at this second
  MyTimestamp.Second   = 30;
  // And now add the alarm to happen when the second matches
  Clock.setAlarm(MyTimestamp, DS3231_Simple::ALARM_MATCH_SECOND);
  // We will set the second alarm to match every minute, since there's
  // no specific time/date data necessary for that we don't have to
  // supply any (but you could if you wanted just like the above).
  Clock.setAlarm(DS3231_Simple::ALARM_EVERY_MINUTE);
  // See comments at bottom of file for more alarm types!
  Serial.println("Waiting for alarms...");
  // To check the alarms we just ask the clock
  uint8_t AlarmsFired = Clock.checkAlarms();
  // Then can check if either alarm is fired (there are 2 alarms possible in the chip)
  // by using a "bitwise and"
  if(AlarmsFired & 1)
    Clock.printTo(Serial); Serial.println(": First alarm has fired!");
  if(AlarmsFired & 2)
    Clock.printTo(Serial); Serial.println(": Second alarm has fired!");
 /* There are 2 different alarms possible in the chip, the first alarm has a
  * resolution of seconds, the second a resolution of minutes.
  * Which alarm gets modified by setAlarm() depends on the type of alarm
  * you want.
  * The following alarm types are available.
  *  (Alarm 1)
  *    ALARM_EVERY_SECOND  (Timestamp not required)
  *    ALARM_MATCH_SECOND
  *    ALARM_MATCH_SECOND_MINUTE
  *    ALARM_MATCH_SECOND_MINUTE_HOUR
  *    ALARM_MATCH_SECOND_MINUTE_HOUR_DATE
  *    ALARM_MATCH_SECOND_MINUTE_HOUR_DOW
  * (Alarm 2)
  *    ALARM_EVERY_MINUTE (Timestamp not required)
  *    ALARM_MATCH_MINUTE
  *    ALARM_MATCH_MINUTE_HOUR
  *    ALARM_MATCH_MINUTE_HOUR_DATE
  *    ALARM_MATCH_MINUTE_HOUR_DOW
  * (Alarm 2)
  *    ALARM_HOURLY   (on the minute of the supplied timestamp *)
  *    ALARM_DAILY    (on the hour and minute *)
  *    ALARM_WEEKLY   (on the hour and minute and day-of-week *)
  *    ALARM_MONTHLY  (on the hour and minute and day-of-month *)
  *  * If set without a timestamp, the current timestamp is used.
Have you tried to print out the value of AlarmsFired to confirm it's the expected value?
arduino_new:
I have little knowledge of Alarms timekeeping. How can I check that AlarmsFired? and what value is expected?
bkrenderman:
You can do Serial.println(AlarmsFired); to print its value. And only you should know what value to expect.
arduino_new:
yes thats fine and as I said Alarm works while connected to Arduino. what I want to do is burn the Alarm time on DS3231 for example Alarm every Minute and then use the DS3231 Alarm itself without Arduino (obviously also connecting external VCC to DS3231) to turn on Latching Circuit.
How I can do that?
How can I do it? please suggest
