DS3231 from adafruit to measure tempature
I am attempting to use a DS3231 RTC from adafruit to measure temperature (Adafruit DS3231 Precision RTC Breakout : ID 3013 : $13.95 : Adafruit Industries, Unique & fun DIY electronics and kits). While it doesn’t specifically say that is can measure the temperature and display it through the serial, I have seen several project with people using variants of the DS3231 to measure temperature.
attached is the code I am using, I have all the necessary libraries to use the DS3231 and I can accurately measure time with it no problem.
-Dan
RTCtemptest.ino (296 Bytes)
What is the problem? What does it print?
Pete
el_supremo:
Pete
It doesn't print anything in the serial monitor.
Change the whole setup function to this
  while(!Serial);
  Serial.println("Init RTC");
  RTC.begin();
  Serial.println("RTC started");
If it prints "Init RTC" but doesn't print "RTC started" then your code is hung up in the initialization of the RTC which usually indicates that you haven't wired it properly.
Pete
