Hello ,
Is it possible to get DS3231 to record in hours:minutes:seconds:milliseconds?
If it is possible, can anyone explain how is it done?
Thank you
Hello ,
Thank you
You could use the int/sqw pin on the DS3231, generate .9765ms interrupts connected to an interrupt pin on the Arduino.
Then deal with this interrupt on the Arduino.
So, I should be connecting SQW on DS3231 to say, pin 2 or 3 on the arduino (promini)?
Is there any sample code or example available to program ?
use the 1Hz output to generate the interrupt. There is example code on the arduino web-site.
The intr.routine just saves "millis()" to a volatile long variable (this marks start of second)
When you want to print time: Read from clock and then add (millis() - the saved millis)
Now the x-tal/RC-osc. takes tare of timing within the full second.
Can you please post the link to the example. I could not find it.
From http://www.arduino.cc/en/Reference/AttachInterrupt
May be like this
const byte interruptPin = 2; // intr 0
volatile unsigned long start_sec; // this is to hold start of sec
byte centi_sec;
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(0, update_sec_start, FALLING); // or RISING
// lots of code here
// read your time: hr,min,sec;
centi_sec = (millis()-start_sec)/10;
// printout time..
void update_sec_start() // this updates every second.
start_sec=millis();
For millisec: Remove /10 and change datatype to int (maybe also the variable_name)
