DS3231 INTERRUPT CONFIGURATION
Hi all,
Greetings!!
I want to set interrupt pin low for 10 seconds in ds3231. Is it possible?
I wanna read data from sensor and send data to server by using ESP8266.
I set an alarm and interrupt pin will connect to a transistor. Load will get the power When ever transistor ON.
Could you please help me how to do?
Regards,
Ram.
No, that's not what an interrupt pin is made for. It's designed to trigger an interrupt.
No, because you didn't post your code. Remember, help is not meant that we will write the sketch for you. If you wrote a sketch and get stuck somewhere, you can post your code, describe your problem and the used hardware in detail and then we will try to help you.
