DS3231 non va?
Ciao
è un giorno che provo...
Arduino nano pin 4 a SDA
pin 5 a SCL
gnd a gnd
3.3 a VCC
led Power ok
ho provato diversi esempi dalle librerie DS3231 e MD_DS3231 ma non ottengo nulla sul monitor seriale.
con questo esempio vedo solo il valore 20
DS3231_test.pde
Eric Ayars
4/11
Test/demo of read routines for a DS3231 RTC.
Turn on the serial monitor after loading this to check if things are
working as they should.
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
	// Start the I2C interface
	Wire.begin();
	// Start the serial interface
	// send what's going on to the serial monitor.
	// Start with the year
	Serial.print("2");
	if (Century) {			// Won't need this for 89 years.
		Serial.print("1");
		Serial.print("0");
	Serial.print(Clock.getYear(), DEC);
	Serial.print(' ');
	// then the month
	Serial.print(Clock.getMonth(Century), DEC);
	Serial.print(' ');
	// then the date
	Serial.print(Clock.getDate(), DEC);
	Serial.print(' ');
	// and the day of the week
	Serial.print(Clock.getDoW(), DEC);
	Serial.print(' ');
	// Finally the hour, minute, and second
	Serial.print(Clock.getHour(h12, PM), DEC);
	Serial.print(' ');
	Serial.print(Clock.getMinute(), DEC);
	Serial.print(' ');
	Serial.print(Clock.getSecond(), DEC);
	// Add AM/PM indicator
	if (h12) {
		if (PM) {
			Serial.print(" PM ");
			Serial.print(" AM ");
		Serial.print(" 24h ");
	// Display the temperature
	Serial.print("T=");
	Serial.print(Clock.getTemperature(), 2);
	// Tell whether the time is (likely to be) valid
	if (Clock.oscillatorCheck()) {
		Serial.print(" O+");
		Serial.print(" O-");
	// Indicate whether an alarm went off
	if (Clock.checkIfAlarm(1)) {
		Serial.print(" A1!");
	if (Clock.checkIfAlarm(2)) {
		Serial.print(" A2!");
	// New line on display
	Serial.print('\n');
	// Display Alarm 1 information
	Serial.print("Alarm 1: ");
	Clock.getA1Time(ADay, AHour, AMinute, ASecond, ABits, ADy, A12h, Apm);
	Serial.print(ADay, DEC);
	if (ADy) {
		Serial.print(" DoW");
		Serial.print(" Date");
	Serial.print(' ');
	Serial.print(AHour, DEC);
	Serial.print(' ');
	Serial.print(AMinute, DEC);
	Serial.print(' ');
	Serial.print(ASecond, DEC);
	Serial.print(' ');
	if (A12h) {
		if (Apm) {
			Serial.print('pm ');
			Serial.print('am ');
	if (Clock.checkAlarmEnabled(1)) {
		Serial.print("enabled");
	Serial.print('\n');
	// Display Alarm 2 information
	Serial.print("Alarm 2: ");
	Clock.getA2Time(ADay, AHour, AMinute, ABits, ADy, A12h, Apm);
	if (ADy) {
	Serial.print(' ');
	Serial.print(' ');
	Serial.print(' ');
	if (A12h) {
		if (Apm) {
			Serial.print('pm');
			Serial.print('am');
	if (Clock.checkAlarmEnabled(2)) {
	// display alarm bits
	Serial.print('\nAlarm bits: ');
	Serial.print(ABits, BIN);
	Serial.print('\n');
	Serial.print('\n');
arrivato guasto ?
il 20 lo ottengo anche senza rtc collegato. penso sia arrivato guasto. la batteria è ok
controlla se viene riconosciuto da Arduino
https://playground.arduino.cc/Main/I2cScanner
rimane fermo così
I2C Scanner
Scanning...
anche senza rtc
I pin da usare per l'i2c sono A4 e A5, non 4 e 5.
si sono lì A4 e A5 gli analog
ho cambiato arduino adesso ha trovato qualcosa
I2C device found at address 0x57  !
I2C device found at address 0x68  !
done
grazie per il test suggerito,era l'arduino .
anche se non capisco, avevo pure testato l'analog read dei pin 4 e 5 e funzionavano correttamente
Non hai capito: quando li usi per l'i2c, quei pin sono obbligati (se li hai puoi usare direttamente i pin marcati SDA e SCL, sono collegati a questi) e non funzionano in modalità analogica.
mi spiego meglio , per testare i pin ho caricato un programmino dove leggevo i valori di analog (non facendo nulla di più) quindi avevo scollegato l'rtc.
