I bought them on lazada.co.th
Link
I tried it with Adafruit library, as well as with this:
name=DS3231
version=1.1.2
author=Andrew Wickert <awickert@umn.edu>, Eric Ayars, Jean-Claude Wippler, Northern Widget LLC <info@northernwidget.com>
If it gets hot or warm i think it is dead.
PS: I do not use any RTC library now - just created a function to read the data array from the chip via the Wire interface.
and
I started to buy a few chips at time even if I need just one. They often come faulty
Ok, after further evaluation, testing and research, i am 90% sure that the ICs that i bought off aliexpress are faulty and a scam, i can confirm this since recently a new review under the product popped up indicating my same exact issue. Another confirmation is this: the DS3231 should work by itself without interfacing it with arduino, since the interfacing with arduino is needed only to set the time and read it, but by itself once voltage is applied it shold output the signal from SCL and SDA. But instead the output is totally wrong.
I now ordered three DS3231 chips from a more serious site (infact they are 10 times more expensive) and i hope that this time it will work correctly as intended
