So I have this general utility class, part of which includes some functions that revolve around a DS3231 RTC using Rtclib. I found myself doing:
DateTime now = rtc.now();
char[] buf = "MM-DD-YYYY";
String t = now.toString(buf);
a lot and wanted to simplify my life by adding the function the utility class. I didn’t put it in the main .ino file just because the class can be used for other implementations on the same hardware.
Unfortunately a simple test like:
#include <Esper.h>
Esper sys(0x4D, 14, 15);
sys.resetI2C();
if (!sys.initRtc()) {
Serial.println(F("Failed to initialize RTC!"));
delay(2000);
ESP.restart();
Serial.println(sys.rtcTimeString());
delay(1500);
Results in:
01/05/20 03:15:45
01/05/20 03:15:45
01/05/20 03:15:45
For some reason the time isn’t ticking up when using the utility class I created.
Using the default RTClib example everything works fine, as well as previous implementations where I had the first code block in the .ino so it isn’t a hardware issue.
I’ve attached my utility class below.
I have a feeling that it is something to do with instances but I’m not that great with C.
Note: on restarting the device the time updates to the correct time but then continues outputting that same time as before.
Esper.cpp (7.99 KB)
Esper.h (1.75 KB)
