Ds3231 on time off time into next day
Hi everyone,
I have a setup i'm testing to be used to trigger a relay on and off
currently it is in test with an LED in place of the relay for simplicity
The below sketch works perfect as long as on time and off time are in the same day
however when i set on time to 18:00 and off time to 6:00 (next day) it does not work
I am looking for some input on where to change the code to facilitate an off time after midnight
#include "RTClib.h"
RTC_DS3231 rtc;
int tempC;
int tempF;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
const uint8_t ontime = 17; // set the stating hour
const uint8_t offtime = 20;  // set the finish hour
const int ledPin = 15;
char dateBuffer[12];
void setup () {
  Wire.begin();
  rtc.begin();
  pinMode(15, OUTPUT); // currently an led for testing
void loop () {
  tempC = rtc.getTemperature();
  tempF = (tempC * 1.8) + 32.0; // Convert C to F
  DateTime now = rtc.now();
  if ((ontime <= now.hour()) && (now.hour() <= offtime))
    // turn LED on:
    digitalWrite(ledPin, HIGH);
      Serial.println("currently in time range, led on");
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print('/');
  Serial.print(now.year(), DEC);
  Serial.print(" (");
  Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
  Serial.print(") ");
  sprintf(dateBuffer, "%02u:%02u:%02u ", now.hour(), now.minute(), now.second());
  Serial.println(dateBuffer);
  Serial.print("Temperature: ");
  Serial.print(tempF);
  Serial.println(" F");
  Serial.println(" ");
  delay(60000);
How about, you describe the logic, we tell you how it can be coded. Hint: if it's after 18:00 or else before 06:00, does that sound right? :slight_smile:
Ok, the logic of this project is to turn on a relay at 6pm and turn off the relay at 6am.
I am using an Arduino Uno Every with a DS 3231 RTC attached.
My coding works as long as it is same day. ie, on at 10am off at 10pm
as below
const uint8_t ontime = 10; // set the stating hour
const uint8_t offtime = 19; // set the finish hour
that works perfect. The problem comes when the off time hour is less than the on time hour
If it set on time to 6pm (18) and off time to 6am (5)
as below
const uint8_t ontime = 18; // set the stating hour
const uint8_t offtime = 5; // set the finish hour
It no longer operates. I have read all the documentation I can find but cannot figure out how to tell it that offtime is the next day
Was my suggestion meaningless to you?
IMO, time comparisons are best done using Epoch Time.
Yeah, I was going to say that but it's a rabbit hole.
Welcome
If offtime is less than ontime, then invert your comparisons
Come on. If it's after 18:00 or before 06:00, it turns off the next day...
well that was what i thought when i set it up, however in testing it just doesn't work
I'm quite new at this programming Arduino code and this just seems like it should work... but it doesn't. It's not all that important so i'll play around with it, and the suggestions to try to achieve my goal. Thanks for your input
"doesn't work" tells nothing - what happens? Also if you have made other attempts you should post those. What is the "it" that should work?
when both times are in the same day the LED lights and goes off as it should between the selected hours
but when end time is the next day at 6am the code below does not turn on my LED at all
It's like the code doesn't know that i'm between the selected times and defaults to the else of LED off
Yes, because you're saying, "if it is now after 18:00 and before 06:00". Does that seem right to you? Think of a number that is greater than 18 and less than 6.
Hi @mr_jim
try this code:
#include "RTClib.h"
RTC_DS3231 rtc;
int tempC;
int tempF;
const uint8_t offtime = 6;  // set the finish hour
bool sequence = true;
void setup () {
  Wire.begin();
  rtc.begin();
void loop () {
  if (ontime == now.hour() and digitalRead(ledPin) ==  LOW)
    // turn LED on:
  if (offtime == now.hour() and digitalRead(ledPin) ==  HIGH)
    // turn LED off:
  Serial.print('/');
  Serial.print('/');
  Serial.print(" (");
  Serial.print(") ");
  delay(60000);
In people time it is perfectly clear, I would know that's between 6pm and 6am without question.
However i see your point that in computer logic there is no match ever because there is no number between those parameters. If I set it ti it is now after 18:00 and before 23:00 it works because there is a match. So any suggestions on how to tell the program that the 6am is the next day? like i said i'm quite new and trying my best to learn this without being a bother to others.
My goal is just a bit of help in coding this so the program understands what i want.
But I told you. Twice.
I uploaded the code and no LED on
however it did give me some new direction alternatives to play with so Thanks
Code in reply #14 has a feature you should adopt. It only sets and clears the LED once per day. That is why it didn't come on immediately. Your code sets it 100 billion times a day. :slight_smile:
Here is how I do it : t940083.ino - Wokwi Arduino and ESP32 Simulator
This method has several advantages over simpler codes like the one from ruilviana
Hi @mr_jim
I don't understand why it didn't work for you.
Here it worked as expected.
To test here I changed from hours to seconds and changed the delay at the end of the code to 1 second (delay(1000)).
#include "RTClib.h"
RTC_DS3231 rtc;
int tempC;
int tempF;
const uint8_t ontime = 28; // set the stating hour
void setup () {
  Wire.begin();
  rtc.begin();
  pinMode(ledPin, OUTPUT); // currently an led for testing
void loop () {
  //if (ontime == now.hour() and digitalRead(ledPin) ==  LOW)
  if (ontime == now.second() and digitalRead(ledPin) ==  LOW)
    // turn LED on:
  //if (offtime == now.hour() and digitalRead(ledPin) ==  HIGH)
  if (offtime == now.second() and digitalRead(ledPin) ==  HIGH)
    // turn LED off:
  Serial.print('/');
  Serial.print('/');
  Serial.print(" (");
  Serial.print(") ");
  //delay(60000);
OP didn't wait several hours for the result. His code runs 100 billion times a day so it reacts instantly.
