DS3231 RTC and Adafruits Lib
Hello my friends :slight_smile:
I got a problem using the DS3231 RTC. I used several libs but the return of the dates and time is not working exactly.
Pluged RTC modul to Arduino Nano.
Installed the Adafruit Lib.
Used the example Sketch for a test:
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
  delay(3000); // wait for console opening
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower()) {
    Serial.println("RTC lost power, lets set the time!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop () {
    DateTime now = rtc.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(" (");
    Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
    Serial.print(") ");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    delay(3000);
Result:
Serial Monitor gives sometimes the right dates/the right time, but often i does not.
2018/8/13 (Monday) 15:15:48
 since midnight 1/1/1970 = 1534173348s = 17756d
2165/82/123 (Sunday) 146:142:5
 since midnight 1/1/1970 = 2038686829s = 23595d
2018/8/13 (Monday) 15:15:54
 since midnight 1/1/1970 = 1534173354s = 17756d
What am i doing wrong!!! Using an other Lib gave similar wrong results…
Tx for watching and tx for help :slight_smile:
Solved:
I was using cheap wires. The female-header-wires seem not to fit very good. Changing the wires to better ones gave constant right results.
Freaky! Never had such problems, but that was the very last thing i could try.
So: If RTC gives back bullshit, remember me and change the wires :D
Thank u all!
Once you fixed the problem, why would you need to try anything else?
Or, do what you are supposed to do, and solder them in place.
