DS3231 RTC- Problems [SOLVED]
Hey all. I am using the DS3231 RTC module for a real time clock. However, my code is not working. At present, I am trying to set the clock. Here is my code:
#include "Wire.h"
#define DS3231_I2C_ADDRESS 0x68
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return( (val/16*10) + (val%16) );
  Wire.begin();
  // set the initial time here:
  // DS3231 seconds, minutes, hours, day, date, month, year
setDS3231time(30,42,21,4,26,11,14);
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
  // sets time and date data to DS3231
  Wire.beginTransmission(DS3231_I2C_ADDRESS);
  Wire.write(0); // set next input to start at the seconds register
  Wire.write(decToBcd(second)); // set seconds
  Wire.write(decToBcd(minute)); // set minutes
  Wire.write(decToBcd(hour)); // set hours
  Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
  Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
  Wire.write(decToBcd(month)); // set month
  Wire.write(decToBcd(year)); // set year (0 to 99)
  Wire.endTransmission();
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  Wire.write(0); // set DS3231 register pointer to 00h
  Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
  // request seven bytes of data from DS3231 starting from register 00h
  *second = bcdToDec(Wire.read() & 0x7f);
  *minute = bcdToDec(Wire.read());
  *hour = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month = bcdToDec(Wire.read());
  *year = bcdToDec(Wire.read());
void displayTime()
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  // retrieve data from DS3231
  readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
  &year);
  // send it to the serial monitor
  Serial.print(hour, DEC);
  // convert the byte variable to a decimal number when displayed
  Serial.print(":");
  if (minute<10)
    Serial.print("0");
  Serial.print(minute, DEC);
  Serial.print(":");
  if (second<10)
    Serial.print("0");
  Serial.print(second, DEC);
  Serial.print(" ");
  Serial.print(dayOfMonth, DEC);
  Serial.print("/");
  Serial.print(month, DEC);
  Serial.print("/");
  Serial.print(year, DEC);
  Serial.print(" Day of week: ");
  switch(dayOfWeek){
  case 1:
    Serial.println("Sunday");
  case 2:
    Serial.println("Monday");
  case 3:
    Serial.println("Tuesday");
  case 4:
    Serial.println("Wednesday");
  case 5:
    Serial.println("Thursday");
  case 6:
    Serial.println("Friday");
  case 7:
    Serial.println("Saturday");
  displayTime(); // display the real-time clock data on the Serial Monitor,
  delay(1000); // every second
But, when I try to compile, I get this message:
exit status 1
'setDS3231time' was not declared in this scope
Any help please? (At present I can't set my clock! :o )
Move the setDS3231time function in front of the setup function.
Pete
el_supremo:
Pete
I did that, but... I got an error!
"expected constructor, destructor, or type conversion before '(' token"
WesleyRTech:
FWIW, I tested the originally posted code and it compiled fine for me, using IDE V1.6.5. I didn't need to move anything up before 'setup()'.
Still, some later versions of the IDE are a bit fussy about forward declarations. I'd say you just made a mistake when moving the function. This compiles without problems for me, (for both UNO and Mega2560):-
#include "Wire.h"
    return ( (val / 10 * 16) + (val % 10) );
    return ( (val / 16 * 10) + (val % 16) );
    Wire.begin();
    setDS3231time(30, 42, 21, 4, 26, 11, 14);
                    byte *minute,
                    byte *hour,
                    byte *dayOfWeek,
                    byte *dayOfMonth,
                    byte *month,
                    byte *year)
void displayTime()
                   &year);
    Serial.print(":");
    if (minute < 10)
        Serial.print("0");
    Serial.print(":");
    if (second < 10)
        Serial.print("0");
    Serial.print(" ");
    Serial.print("/");
    Serial.print("/");
    switch (dayOfWeek)
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
Are you by chance using the dreaded IDE V1.6.8?
OldSteve:
Um... yes, Is that bad? :o
WesleyRTech:
A lot of people have had trouble with V1.6.8. V1.6.5 was the last really stable version of the IDE. (That's why I haven't upgraded.)
From what I've heard, many issues will be fixed in V1.6.9, but I'll wait until a few 'guinea pigs' have tested it. :smiley:
Is the modified version of your code that I posted compiling OK?
OldSteve:
OldSteve:
I uninstalled IDE 1.6.8, and got 1.6.5.
I tried the original code with that
And... IT WORKED!
Thanks so much for the help!
@YoungSteve
Are you running 1.65 ?
If so, what do you see is the advantage over 1.06 ?
WesleyRTech:
And... IT WORKED!
Excellent. I'm glad that solved it. With 1.6.5 you're less likely to have other problems, too.
LarryD:
@YoungSteve
I really couldn't say, Larry. I've never used 1.0.6. I only started using Arduino when V1.6.5 was released.
The Arduino IDE actually teaches bad habits :wink:
To OP
instead of moving the complete function, you could have added a line just before setup like
/* function prototypes */
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte dayOfMonth, byte month, byte year);
// add more prototypes here if needed
I use OldSteve's solution for made a clock with 3 buttons on 1.8"ST3231 display and works...
thx OldSteve... you can see the movie from adjusting clock with thermometer using DS3231 on 1.8" ST7735 display - YouTube
could anyone please explain why we used 0x7f and 0x3f in the read function..
This removes the high-order bit because it isn't part of the seconds.
This removes the two high-order bits because they aren't part of the hours.
In both cases the unused bits are defined to be zero so the 0x7f and 0x3f aren't strictly necessary.
The curious thing is that having removed those bits which were apparently defined in the datasheet to be zero, the code does not remove the high-order bit from the month. This bit defines the century and is zero for this century so the month will be converted correctly for the next 82 years, but then it'll go insane as soon as the year 2100 starts.
Pete
Thank you sir that helped!!
can someone tell how do we set the 12/24 hr modes and the am/pm mode
WesleyRTech:
#include "Wire.h"
  return( (val/1016) + (val%10) );
  return( (val/16
10) + (val%16) );
  Wire.begin();
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
void displayTime()
  &year);
  Serial.print(":");
  if (minute<10)
    Serial.print("0");
  Serial.print(":");
  if (second<10)
    Serial.print("0");
  Serial.print(" ");
  Serial.print("/");
  Serial.print("/");
  switch(dayOfWeek){
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  case 6:
  case 7:
exit status 1
43Jakaria:
Do you have a question?
