Hello!
I’m writing a code for my fish tank, but the temperature sensor’s value wasn’t smooth enough, so I would like to use the “Smooth” example. It 's working fine if I upload just the example, but with my whole code, it isn’t good. Normally it sends a value like 430, but in the big code, it gives me more and more, like 430-560-700-900 and so on.
I’ve figured it out, that it has some problem with the DS3231, if i // just this one row: “byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;”, it’s working fine. Full code attached.
Can the DS3231 internal temp sensor cause this, (maybe the library) or what should I do?
English is not my native language, sorry about that, and thanks for reading this!
#include <DS3231.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#include <LiquidCrystal_SR.h>
#include <LiquidCrystal_SR2W.h>
#include <LiquidCrystal_SR3W.h>
#include <microsmooth.h>
#define aref_voltage 3.3
#include <math.h>
#include <ClickEncoder.h>
#include <TimerOne.h>
#define THERMISTORNOMINAL 10000
#define TEMPERATURENOMINAL 25
#define BCOEFFICIENT 3950
#define SERIESRESISTOR 10000
#define DS3231_I2C_ADDRESS 0x68
DS3231 Clock;
int relay = 11; // relay1 -------
int neon = 12; // relay1 neon lights
int pump = 4; // relay3 pump
int heater = 5; // relay4 heater
int LED = 6; // PWM RED LED
int wls = 8; // Water level switch
int moon = 9; // PWM ORANGE
int fan = 10; // PWM WHITE FAN
int e1 = A2; //Error LED 1 water level
int e2 = A1; //Error LED 2 water temp
int lcdbl = A0; //LCD BackLight
int eled = 13; // Internal Error LED
int temppin = A3; //temp sensor
int wlsv = LOW; // water level value változó
int tempMin = 24; //FAN speed min, 24C
int tempLed = 26;
int tempMax = 26; //FAN speed max, 26C
int FANspeed; //FAN speed változó
int FANsz;
int FANl;
int neonv;
int allminute;
int LED_UPFADEON = 570;
int LED_UPFADEOFF = 600;
int LED_DOWNFADEON = 1320;
int LED_DOWNFADEOFF = 1350;
int LEDv;
int leddisp;
unsigned long previousMillistemp;
unsigned long previousMillistempz;
unsigned long timeoutTime = 10000;
unsigned long previousMilliswlsv;
unsigned long previousMillispump;
int intervalpump = 5000;
int lastvalue = 0;
int menuTimeout = 10000;
int intervaltemp = 1000;
int blinktimetemp = 1000;
int intervalwlsv = 5000;
int blinktimewlsv =50;
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7); // 0x27 is the I2C bus address for an unmodified backpack
byte decToBcd(byte val) {return( (val/10*16) + (val%10) );}
byte bcdToDec(byte val){return( (val/16*10) + (val%16) );}
bool h12;
bool PM;
ClickEncoder *encoder;
int16_t last, value;
void timerIsr() {encoder->service();}
float steinhart;
long uptimedays=0;
long uptimehours=0;
long uptimemins=0;
long uptimesecs=0;
int const offpump = 5;
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average1; // the average
Wire.begin();
pinMode (neon, OUTPUT);
pinMode (heater, OUTPUT);
pinMode (pump, OUTPUT);
pinMode (LED, OUTPUT);
pinMode (wls, INPUT_PULLUP);
pinMode (moon, OUTPUT);
pinMode (fan, OUTPUT);
pinMode (e1, OUTPUT);
pinMode (e2, OUTPUT);
pinMode (eled, OUTPUT);
pinMode (temppin, INPUT);
pinMode (lcdbl, OUTPUT);
digitalWrite (pump, HIGH); ///////////
lcd.begin (16,2); // for 16 x 2 LCD module
lcd.setBacklightPin(3,POSITIVE);
lcd.setBacklight(HIGH);
analogReference(EXTERNAL);
digitalWrite (heater, HIGH);
digitalWrite (LED, LOW); //////////
digitalWrite (moon, HIGH); //////////
digitalWrite (fan, LOW);
digitalWrite (eled, LOW);
digitalWrite (e1, HIGH);
digitalWrite (e2, HIGH);
digitalWrite (lcdbl, HIGH);
digitalWrite (e1, LOW);
digitalWrite (e2, LOW);
digitalWrite (neon, LOW);
encoder = new ClickEncoder(2, 3, 7);
Timer1.initialize(1000);
Timer1.attachInterrupt(timerIsr); last = -1;}
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
{ Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set DS3231 register pointer to 00h
Wire.endTransmission();
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
for (int thisReading = 0; thisReading < numReadings; thisReading++) readings[thisReading] = 0;
//hőmérséklet
total = total - readings[readIndex];
readings[readIndex] = analogRead(temppin);
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings)
readIndex = 0;
average1 = total / numReadings;
Serial.println(average1);
delay(100); // delay in between reads for stability
average1 = 1023 / average1 - 1;
average1 = SERIESRESISTOR / average1;
steinhart = THERMISTORNOMINAL / average1 ; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.4; // convert to C
Serial.print("Temperature ");
Serial.print(steinhart);
Serial.println(" *C");
//idő
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; // retrieve data from DS3231
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
allminute=(hour*60+minute);
nagyprojekt.ino (11.9 KB)
