Bonjour, j'utilise ce code la pour lire l'heure et la date avec un ds3231, une fois que je lance le serial monitor , y m'affiche des caractère incohérents .
* Display the date and time from a DS3231 or DS3232 RTC every second. *
* Display the temperature once per minute. (The DS3231 does a *
* temperature conversion once every 64 seconds. This is also the *
* default for the DS3232.) *
* Set the date and time by entering the following on the Arduino *
* serial monitor: *
* year,month,day,hour,minute,second, *
* Where *
* year can be two or four digits, *
* month is 1-12, *
* day is 1-31, *
* hour is 0-23, and *
* minute and second are 0-59. *
* Entering the final comma delimiter (after "second") will avoid a *
* one-second timeout and will allow the RTC to be set more accurately. *
* No validity checking is done, invalid values or incomplete syntax *
* in the input will result in an incorrect RTC setting. *
* Jack Christensen 08Aug2013 *
* Tested with Arduino 1.0.5, Arduino Uno, DS3231/Chronodot, DS3232. *
* This work is licensed under the Creative Commons Attribution- *
* ShareAlike 3.0 Unported License. To view a copy of this license, *
* visit http://creativecommons.org/licenses/by-sa/3.0/ or send a *
* letter to Creative Commons, 171 Second Street, Suite 300, *
* San Francisco, California, 94105, USA. *
#include <DS3232RTC.h> //http://github.com/JChristensen/DS3232RTC
#include <Streaming.h> //http://arduiniana.org/libraries/streaming/
#include <Time.h> //http://playground.arduino.cc/Code/Time
#include <Wire.h> //http://arduino.cc/en/Reference/Wire
void setup(void)
//setSyncProvider() causes the Time library to synchronize with the
//external RTC by calling RTC.get() every five minutes by default.
setSyncProvider(RTC.get);
Serial << F("RTC Sync");
if (timeStatus() != timeSet) Serial << F(" FAIL!");
Serial << endl;
void loop(void)
static time_t tLast;
time_t t;
tmElements_t tm;
//check for input to set the RTC, minimum length is 12, i.e. yy,m,d,h,m,s
if (Serial.available() >= 12) {
//note that the tmElements_t Year member is an offset from 1970,
//but the RTC wants the last two digits of the calendar year.
//use the convenience macros from Time.h to do the conversions.
int y = Serial.parseInt();
if (y >= 100 && y < 1000)
Serial << F("Error: Year must be two digits or four digits!") << endl;
else {
if (y >= 1000)
tm.Year = CalendarYrToTm(y);
else //(y < 100)
tm.Year = y2kYearToTm(y);
tm.Month = Serial.parseInt();
tm.Day = Serial.parseInt();
tm.Hour = Serial.parseInt();
tm.Minute = Serial.parseInt();
tm.Second = Serial.parseInt();
t = makeTime(tm);
RTC.set(t); //use the time_t value to ensure correct weekday is set
setTime(t);
Serial << F("RTC set to: ");
printDateTime(t);
Serial << endl;
//dump any extraneous input
while (Serial.available() > 0) Serial.read();
t = now();
if (t != tLast) {
tLast = t;
printDateTime(t);
if (second(t) == 0) {
float c = RTC.temperature() / 4.;
float f = c * 9. / 5. + 32.;
Serial << F(" ") << c << F(" C ") << f << F(" F");
Serial << endl;
//print date and time to Serial
void printDateTime(time_t t)
printDate(t);
Serial << ' ';
printTime(t);
//print time to Serial
void printTime(time_t t)
printI00(hour(t), ':');
printI00(minute(t), ':');
printI00(second(t), ' ');
//print date to Serial
void printDate(time_t t)
printI00(day(t), 0);
Serial << monthShortStr(month(t)) << _DEC(year(t));
//Print an integer in "00" format (with leading zero),
//followed by a delimiter character to Serial.
//Input value assumed to be between 0 and 99.
void printI00(int val, char delim)
if (val < 10) Serial << '0';
Serial << _DEC(val);
if (delim > 0) Serial << delim;
return;
