I'm having trouble using the DS3234 Rtc Chip, and after, reading all the posts, I see I'm not alone. Below is a sample output when I run the following Sparkfun example code. As you can see there is a repeatable pattern that doesn't make any sense every five lines, why I don't know. I have the interrupt connected but am not using it at this moment. I modified the code to read the DS3234 25 times and then wait forever. This is just a test mod and will be removed when it works. Any one have any ideas?
Any help will be greatly appreciated.
Hugh
#include <SPI.h>
const int cs=10; //chip select
RTC_init();
//day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59)
SetTimeDate(11,12,13,14,15,16);
for(int zz = 0;zz < 25; zz++){
Serial.println(ReadTimeDate());
while(1){}
int RTC_init(){
pinMode(cs,OUTPUT); // chip select
// start the SPI library:
SPI.begin();
SPI.setBitOrder(LSBFIRST);
SPI.setDataMode(SPI_MODE1); // both mode 1 & 3 should work
//set control register
digitalWrite(cs, LOW);
SPI.transfer(0x8E);
SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
digitalWrite(cs, HIGH);
delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
int TimeDate [7]={
s,mi,h,0,d,mo,y };
for(int i=0; i<=6;i++){
if(i==3) i++;
int b= TimeDate*/10;*
int a= TimeDate_-b10;_
_ if(i==2){_
_ if (b==2)_
_ b=B00000010;_
_ else if (b==1)_
_ b=B00000001;_
_ } _
_ TimeDate= a+(b<<4);
SPI.transfer(i+0x80);
SPI.transfer(TimeDate);
String ReadTimeDate(){
String temp;
int TimeDate [7]; //second,minute,hour,null,day,month,year
if(i==3)
i++;
SPI.transfer(i+0x00);
unsigned int n = SPI.transfer(0x00);
int a=n & B00001111;
if(i==2){
int b=(n & B00110000)>>4; //24 hour mode*
* if(b==B00000010)
b=20;
else if(b==B00000001)
b=10;
TimeDate=a+b;
else if(i==4){
TimeDate=a+b10;
else if(i==5){
int b=(n & B00010000)>>4;
TimeDate=a+b10;
else if(i==6){
int b=(n & B11110000)>>4;
TimeDate=a+b10;
else{
int b=(n & B01110000)>>4;
TimeDate=a+b10;
temp.concat(TimeDate[4]);
temp.concat("/") ;
temp.concat(TimeDate[5]);
temp.concat("/") ;
temp.concat(TimeDate[6]);
temp.concat(" ") ;
temp.concat(TimeDate[2]);
temp.concat(":") ;
temp.concat(TimeDate[1]);
temp.concat(":") ;
temp.concat(TimeDate[0]);
return(temp);
Generated output:
0/0/10 12:2:20
0/0/2 0:33:0
10/0/33 0:0:12
2/12/0 20:0:40
33/0/0 0:10:0
0/0/10 12:2:20
0/0/2 0:33:0
10/0/33 0:0:12
2/12/0 20:0:40
33/0/0 0:10:0
0/0/10 12:2:20
0/0/2 0:33:0
10/0/33 0:0:12
2/12/0 20:0:40
33/0/0 0:10:0
0/0/10 12:2:20
0/0/2 0:33:0
10/0/33 0:0:12
2/12/0 28:0:40
33/0/0 0:10:0
0/0/10 12:2:28
0/8/2 0:33:0
10/0/33 0:0:12
2/12/0 28:0:40
33/0/0 0:10:0_
