DS3234 and SD card
Hi all,
I am currently using a RTC DS3234 together with microSD card to do data logger for sensor MPU6050. For data logging, the code I am using is the modification of lowlatencylogger from sdfat example. When I try to implement the RTC into this code, it just doesnt work and my complete code can be seen in the attached file.
What I need is simply show the real time for each data taken from the sensor. Since DS3234 is an SPI device, the cs pin for DS3234 I had selected 10 and for microSD card shield I had selected 8. The rest (MISO, MOSI, SCK) remain the same.
So can anyone pointed out where did I get wrong?
Back.ino (14.7 KB)
UserDataType.h (305 Bytes)
I doubt that you meant this!
  sd.begin(38400);
Pete
el_supremo:
  sd.begin(38400);
Pete
Hi thanks for reply,
but i do not understand what you trying to say. Can you please elaborate?
Thank you.
An SD card doesn’t have a baud rate. So trying to initialize it at 38400 baud doesn’t make sense, especially when you correctly initialize it 15 lines further down:
 // initialize file system.
  if (!sd.begin(SD_CS_PIN, SPI_FULL_SPEED)) {
Delete the line with “sd.begin(38400);”.
Pete
el_supremo:
An SD card doesn't have a baud rate. So trying to initialize it at 38400 baud doesn't make sense, especially when you correctly initialize it 15 lines further down:
Delete the line with "sd.begin(38400);".
Pete
Thank you so much for your explanation. I really had no idea about this. Thanks for the information.
:slight_smile:
