I'm using the library for the DS3234 found here:GitHub - rodan/ds3234: arduino library for DS3234 RTC
I've got alarms to work, but now I need to deactivate one. This line is what activates, but I don't understand bits and stuff enough to figure out how to turn off Alarm 1.
// activate Alarm1
DS3234_set_creg(cs, DS3234_INTCN | DS3234_A1IE);
Bit 1: Alarm 2 Interrupt Enable (A2IE). When set to logic 1, this bit permits the alarm 2 flag (A2F) bit in the status register to assert INT/SQW (when INTCN = 1). When the A2IE bit is set to logic 0 or INTCN is set to logic 0, the A2F bit does not initiate an interrupt signal. The A2IE bit is disabled (logic 0) when power is first applied.
Bit 0: Alarm 1 Interrupt Enable (A1IE). When set to logic 1, this bit permits the alarm 1 flag (A1F) bit in the status register to assert INT/SQW (when INTCN = 1). When the A1IE bit is set to logic 0 or INTCN is set to logic 0, the A1F bit does not initiate the INT/SQW sig- nal. The A1IE bit is disabled (logic 0) when power is first applied.
taken from the data sheet:
When I activate alarm 1, I need to deactivate alarm 2, because it could fire off prematurely. And vise versa--when I activate alarm 2, I need to deactivate alarm 1. I know it must be simple…
thanks
