DS3234, interrupts and alarms
Hello,
I have a DS3234 RTC configured to trigger an alarm every 5 minutes to wake up the Arduino, the problem is that the interrupt on pin 2 appears to freeze completely the Arduino, if I don't sleep the arduiuno also be blocked when interrupt is activated, somebody can help me?
The code is:
#include <SPI.h>
#include "ds3234.h"
#include "Enerlib.h"
#define BUFF_MAX 256
const int cs = 8;              // chip select pin
uint8_t sleep_period = 5;       // the sleep interval in minutes between 2 consecutive alarms
Energy energy;
// how often to refresh the info on stdout (ms)
//unsigned long prev = 5000, interval = 5000;
void set_next_alarm(void)
    struct ts t;
    unsigned char wakeup_min;
    DS3234_get(cs, &t);
    // calculate the minute when the next alarm will be triggered
    wakeup_min = (t.min / sleep_period + 1) * sleep_period;
    if (wakeup_min > 59) {
        wakeup_min -= 60;
    // flags define what calendar component to be checked against the current time in order
    // to trigger the alarm
    // A2M2 (minutes) (0 to enable, 1 to disable)
    // A2M3 (hour)    (0 to enable, 1 to disable)
    // A2M4 (day)     (0 to enable, 1 to disable)
    // DY/DT          (dayofweek == 1/dayofmonth == 0)
    boolean flags[4] = { 0, 1, 1, 1 };
    // set Alarm2. only the minute is set since we ignore the hour and day component
    DS3234_set_a2(cs, wakeup_min, 0, 0, flags);
    // activate Alarm2
    DS3234_set_creg(cs, DS3234_INTCN | DS3234_A2IE);
void INT0_ISR(void)
  The WasSleeping function will return true if Arduino
  was sleeping before the IRQ. Subsequent calls to
  WasSleeping will return false until Arduino reenters
  in a low power state. The WasSleeping function should
  only be called in the ISR.
  detachInterrupt(0);
  set_next_alarm();
  // clear a2 alarm flag and let INT go into hi-z
  DS3234_clear_a2f(cs);
  Serial.println(" Entering interrupt 0");
  if (energy.WasSleeping())
    Arduino was waked up by IRQ.
    If you shut down external peripherals before sleeping, you
    can reinitialize them here. Look on ATMega's datasheet for
    hardware limitations in the ISR when microcontroller just
    leave any low power state.
    Serial.println("  Interrupt and was sleeping");
    The IRQ happened in awake state.
    This code is for the "normal" ISR.
    Serial.println("  Interrupt and was NOT sleeping");
  Serial.println(" Exiting interrupt 0");
    Serial.println("Entering setup");
    pinMode(2, INPUT);
    delay(5000);
    DS3234_init(cs, DS3234_INTCN);
    set_next_alarm();
    attachInterrupt(0, INT0_ISR, LOW);
  Serial.println("Entering loop");
  delay(5000);
  Serial.println("Powering down");
  energy.PowerDown();
  char buff[BUFF_MAX];
  struct ts t;
  DS3234_get(cs, &t);
  // display current time
  snprintf(buff, BUFF_MAX, "%d.%02d.%02d %02d:%02d:%02d", t.year, t.mon, t.mday, t.hour, t.min, t.sec);
  Serial.println(buff);
A lot of thanks
  1. interrupt routine should be kept as short as possible.
  2. Do not call detachInerrupt() in side the routine
  3. You can not use anything which requires interrupts form inside an interrupt routine this includes Serial!
Mark
Hello Mark,
I rewrite my code, and the problems is the same.
Code:
#include <SPI.h>
#include "ds3234.h"
Energy energy;
int time_interrupt=0;
    struct ts t;
    DS3234_get(cs, &t);
        wakeup_min -= 60;
    // activate Alarm2
void INT0_ISR(void)
  //detachInterrupt(0);
  time_interrupt=1;
    pinMode(2, INPUT);
    delay(5000);
    set_next_alarm();
  if(time_interrupt==1){
    Serial.println("time_interrupt==1");
    time_interrupt=0;
  //Serial.println("Powering down");
  //energy.PowerDown();
  struct ts t;
  DS3234_get(cs, &t);
I can't see if you are doing this, but when an alarm occurs you must clear the INTCN bit (bit 2) in the control register to reset it ready for the next alarm. You would do this in the loop() function each time that time_interrupt is set.
I also think it would be a lot easier to just set the alarm to interrupt every minute. You then initialize a counter to sleep_period and count it down on each interrupt until it reaches zero. That would avoid having to calculate the next value required for the alarm.
Pete
Now it works!
I need an alarm that wake up the Arduino every 5 minutes or more.
Code:
#include <SPI.h>
#include "ds3234.h"
Energy energy;
    struct ts t;
    DS3234_get(cs, &t);
        wakeup_min -= 60;
    // activate Alarm2
void INT0_ISR(void)
  //detach interrupt and set time_interrupt=1
  //interrupt must be attached again
  detachInterrupt(0);
  time_interrupt=1;
    pinMode(2, INPUT);
    delay(5000);
    set_next_alarm();
    Serial.println(" time_interrupt==1");
    time_interrupt=0;
    // set next alarm
    set_next_alarm();
    //Attach interrupt again
  //For debuf only
  struct ts t;
  DS3234_get(cs, &t);
  energy.PowerDown();
