DS3234 rtc - gets wrong time
Hello,
I have an Arduino uno, DS3234 RTC and 8pc of 8digit led. But It gets wrong time and date (randomly?) for example it's 2013/12/01 now. I don't know if the rtc is bad or something in the code? Any idea?
#include <SPI.h>
#include <LedControl.h>
#include <avr/interrupt.h>
const byte DIN = 6;              // Pin 1  on the Max72xx
const byte CLK = 8;              // Pin 13 on the Max72xx
const byte LOADCS = 7;           // Pin 12 on the Max72xx
const byte cs=10; //chip select for RTC
byte sleep = 0; // sleep flag
byte sticks = 2; // pin for the clapper
byte run = 0;
byte years=0;
byte months=0;
byte days=0;
byte error=0; // error flag to trigger error code in boot
volatile byte hSecond=0; // these are our time variables
volatile byte seconds=0;
volatile byte minutes=0;
volatile byte hours=0;
LedControl lc=LedControl(DIN,CLK,LOADCS,1);    // DIN, CLK, Load/CS, 1 = only one chip MAX chip attached
byte chip_id = 0;          // This is not strictly reqd, but if using more than one display this will be needed
byte row = 0;              // Set the starting position
byte ledBrightness = 10;    // range is 0-15.  0=lowest, 15 = full power
volatile unsigned char tick_flag = 0;
volatile unsigned char sync_flag = 0;
volatile unsigned char date_flag = 0;
  pinMode(DIN, OUTPUT);        // once only, lets make the 7219 pins outputs
  pinMode(CLK, OUTPUT);
  pinMode(LOADCS, OUTPUT);
  pinMode(sticks, INPUT);
  pinMode(cs,OUTPUT); // chip select for RTC
  for(int index=0;index<lc.getDeviceCount();index++)  // take pins out of power save mode
      lc.shutdown(index,false);
  lc.setIntensity(0,ledBrightness);
  RTC_init();
  //SetTimeDate(9,03,14,22,37,30); //day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59) only if needed
  ReadTimeDate(); // load current RTC time into time variables
  if (hours == 0) {
    error=1;
  boot();
  ReadTimeDate();
//clearSPI();
  Serial.print("muxik");
noInterrupts();
    //This sets Timer1 to interrupt every 1/30 of a second, assunming a clock of 16MHz.
    TCCR1A = 0; // set entire TCCR1A register to 0
    TCCR1B = 0; // same for TCCR1B
    TCNT1  = 0; //initialize counter value to 0
    // set compare match register to desired timer count: 100hz
    OCR1A = 8333; //prescaler at 32 //19999;
    // turn on CTC mode:
    TCCR1B |= (1 << WGM12);
    // Set CS11 bits for 8 prescaler:
    TCCR1B |= (1 << CS11)|(1 << CS10);
        // enable timer compare interrupt:
    TIMSK1 |= (1 << OCIE1A);//|(1 << OCIE1B);
interrupts();
ISR(TIMER1_COMPA_vect)  // This code executes at each interrupt of Timer1
  hSecond++;
  tick_flag = 1; // signal loop that the led should be updated
  if (hSecond < 30) return;
  seconds++;
  hSecond = 0;
  if (seconds < 60) return;
  minutes++;
  seconds = 0;
  if (minutes < 60) return;
  hours++;
  sync_flag = 1;
  minutes = 0;
  if (hours == 24) {
  hours = 0;
  if(digitalRead(sticks)==LOW) {
    date_flag=1;
    //lc.setIntensity(0,3);
    lc.clearDisplay(chip_id);
  else {
    date_flag=0;
    run=0;
    if(tick_flag&&sleep==0&&date_flag==0) {
      led_print(hours, 6);  // Print the hour
      led_print(minutes, 4);  // Print the minutes
      led_print(seconds, 2);  // Print the seconds
      led_print(hSecond, 0); //Print the hundreths of seconds
      tick_flag = 0;
  if(date_flag==1&&run==0)  {
    date();
    run=1;
    //lc.clearDisplay(chip_id);
   if(hours<06 && hours>01) { //sets a sleep flag so the clock display is off late at night to save battery
    sleep=1;
    else {
      sleep=0;
      //lc.setIntensity(0,ledBrightness);
  if(sync_flag) {
    SPI.begin();
    SPI.setBitOrder(MSBFIRST);
    SPI.setDataMode(SPI_MODE3);
    ReadTimeDate();
    //clearSPI();
    sync_flag = 0;
int RTC_init(){
	  // start the SPI library:
	  SPI.begin();
	  SPI.setDataMode(SPI_MODE3); // both mode 1 & 3 should work
	  //set control register
	  digitalWrite(cs, LOW);
	  SPI.transfer(0x8E);
	  SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
	  digitalWrite(cs, HIGH);
	  delay(10);
void clearSPI() {
  SPI.begin();
  SPI.end();
String ReadTimeDate(){
	String temp;
	int TimeDate [7]; //second,minute,hour,null,day,month,year
	for(int i=0; i<=6;i++){
		if(i==3)
			i++;
		SPI.transfer(i+0x00);
		unsigned int n = SPI.transfer(0x00);
		int a=n & B00001111;
		if(i==2){
			int b=(n & B00110000)>>4; //24 hour mode
			if(b==B00000010)
				b=20;
			else if(b==B00000001)
				b=10;
			TimeDate[i]=a+b;
		else if(i==4){
			TimeDate[i]=a+b*10;
		else if(i==5){
			int b=(n & B00010000)>>4;
			TimeDate[i]=a+b*10;
		else if(i==6){
			int b=(n & B11110000)>>4;
			TimeDate[i]=a+b*10;
		else{
			int b=(n & B01110000)>>4;
			TimeDate[i]=a+b*10;
        hours = TimeDate[2];
        minutes = TimeDate[1];
        seconds = TimeDate[0];
        years = TimeDate[6];
        months = TimeDate[5];
        days = TimeDate[4];
  return(temp);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
	int TimeDate [7]={s,mi,h,0,d,mo,y};
		if(i==3)
			i++;
		int b= TimeDate[i]/10;
		int a= TimeDate[i]-b*10;
		if(i==2){
			if (b==2)
				b=B00000010;
			else if (b==1)
				b=B00000001;
		TimeDate[i]= a+(b<<4);
		SPI.transfer(i+0x80);
		SPI.transfer(TimeDate[i]);
void led_print(int time_int, int pos){              // Ask for the number and the position to print
  byte ones, tens;                                  // A couple of variables to fill with digits
  ones=time_int%10;                                 // %10 divides by ten and extracts the remainder
  tens=time_int/10%10;                              // Handy for splitting the digits in two for printing
  lc.setDigit(chip_id, pos, (byte) ones, true);    // These two lines send the digits to the Max7221
  lc.setDigit(chip_id, pos+1, (byte) tens, false);  // one by one
void date() {
  digitalWrite(LOADCS, HIGH);
  led_print(days, 6);  // Print the day
  led_print(months, 4);  // Print the month
  lc.setChar(chip_id, 3, 2, false);  // "2"
  lc.setChar(chip_id, 2, 0, false);  // "0"
  led_print(years, 0);  // Print the year
  //detachInterrupt(0);
void boot() {
  ledSync();
  ledBat();
  ledDash();
  if (error) {
    ledSyncEr();
    error=0;
void ledSync() {
  lc.setRow(chip_id, 6, 61); // "d"
  lc.setRow(chip_id, 5, 13); // "c"
  lc.setRow(chip_id, 4, 29); // "o"
  lc.setRow(chip_id, 3, 61); // "d"
  lc.setRow(chip_id, 2, 79); // "E"
  lc.setChar(chip_id, 1, 3, true);  // "3"
  lc.setChar(chip_id, 0, 0, false);  // "0"
void ledSyncEr() {
  lc.setRow(chip_id, 7, 91); // "S or 5"
  lc.setRow(chip_id, 6, 21); // "n"
  lc.setRow(chip_id, 3, 79); // "E"
  lc.setRow(chip_id, 2, 5); // "r"
  lc.setChar(chip_id, 1, 3, false);  // "3"
void ledBat() {
  lc.setRow(chip_id, 6, 31);  //"b"
  lc.setRow(chip_id, 5, 119); //"A"
  lc.setRow(chip_id, 4, 15);  //"t"
  lc.setChar(chip_id, 1, 7, true);  // "7"
void ledDash() {
  for (int r=0; r<=7; r++){
  lc.setChar(chip_id, r, '-', false); // "-"
  delay(300);
There is a library available for this rtc which has examples - I’d suggest you try that to see if your clock is ok .
I’m unsure what your sketch is tying to do .
I don’t get it, are you using an RTC or using this logic to keep time?
Did you write this code?
Also, you can use constants like ‘E’ instead of numbers you need to write a comment to explain.
a7
No it's actually not my code, i got it from here:
And I recreated this exect timecode slate, the only difference is I used an arduino uno. This thing is showing you: hh/mm/ss/(framerate)
I hope it's more understandable now:)
I already tried the sparkfun DS3234 demo and I got some weird texts in the serial monitor.
OK, thanks for the additional. Information.
Assuming the instructabke guy had a working thing, I know, a huge leap of faith, you are with few possibilities.
So.
Try a simple example sketch to confirm the operation and connections of the RTC.
Check your wiring for mistakes and/or loose or sloppy connections.
Make sure you have an adequate clean source of power.
How are you powering it? How is it wired now? Did you just build the whole thing?
Even with a fine guided tour like instructsables, cough!, it is prudent to build and test the separate elements before you cram everything together and hit the On button.
a7
It already worked for me when it was only test wired. And now it's not working... it's weird. So I guess the code is still good. But thanks I will check the cables.
When I sync with the pc I use the usb as connection and power.
