DS4GAMEPAD_DPAD_CENTERED no scope found
In this code
  • MIT License
  • Copyright (c) 2020 gdsports625@gmail.com
  • Permission is hereby granted, free of charge, to any person obtaining a copy
  • of this software and associated documentation files (the "Software"), to deal
  • in the Software without restriction, including without limitation the rights
  • to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
  • copies of the Software, and to permit persons to whom the Software is
  • furnished to do so, subject to the following conditions:
  • The above copyright notice and this permission notice shall be included in all
  • copies or substantial portions of the Software.
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  • IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  • FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
  • AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  • LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
  • OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
  • SOFTWARE.
Basic (sticks and buttons) gamepad controller for Dual Shock 4
The gamepad has 14 buttons, 2 analog thumbsticks, 1 8-way direction pad,
and 2 analog triggers.
Compared to the Dual Shock 4 controller, the DS4Gamepad does
not have rumble motors, motion sensors (accel/gyro), Bluetooth,
touch pad, and light panel.
Adafruit ItsyBitsy M0/M4 Express
DS4 Button Button Name ItsyBitsy Pin
0 SQUARE 0
1 CROSS 1
2 CIRCLE 2
3 TRIANGLE 3
4 L1 4
5 R1 7
6 L2* -
7 R2* -
8 SHARE 9
9 OPTIONS 10
10 L3# 11
11 R3# 12
12 LOGO$ 13
13 TPAD% SCK
  • L2/R2 = Analog triggers are also reported as buttons but do not need input pins.
L3/R3 = Thumbsticks are also buttons.
$ LOGO = Pin 13 has resistor and LED pulling the pin to ground so it does not work as an input.
Remove the resistor and/or LED to make this work.
% TPAD = touchpad is also a button.
DS4 Axis ItsyBitsy Pin
Left stick X A0
Left stick Y A1
Right stick X A2
Right stick Y A3
Left trigger A4
Right trigger A5
Direction pad requires 4 pins.
MOSI button 1
MISO button 0
SCL button 2
SDA button 3
#define HAS_DOTSTAR_LED (defined(ADAFRUIT_TRINKET_M0) || defined(ADAFRUIT_ITSYBITSY_M0) || defined(ADAFRUIT_ITSYBITSY_M4_EXPRESS))
#if HAS_DOTSTAR_LED
#include <Adafruit_DotStar.h>
#if defined(ADAFRUIT_ITSYBITSY_M4_EXPRESS)
#define DATAPIN 8
#define CLOCKPIN 6
#elif defined(ADAFRUIT_ITSYBITSY_M0)
#define DATAPIN 41
#define CLOCKPIN 40
#elif defined(ADAFRUIT_TRINKET_M0)
#define DATAPIN 7
#define CLOCKPIN 8
#endif
Adafruit_DotStar strip = Adafruit_DotStar(1, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
#endif
#include "HID-Project.h"
#include <Bounce2.h>
// BEWARE: Make sure all these pins are available on your board. Some pins
// may be connected to on board devices so cannot be used as inputs.
#define NUM_BUTTONS 12
const uint8_t BUTTON_PINS[NUM_BUTTONS] = {0, 1, 2, 3, 4, 7, 9, 10, 11, 12, 13, SCK};
#define NUM_DPAD 4
const uint8_t DPAD_PINS[NUM_DPAD] = {MOSI, MISO, SCL, SDA};
// Translate 4 input pins to dpad direction values
const uint8_t DPAD_MAP[16] = {
// LDRU
DS4GAMEPAD_DPAD_CENTERED, // 0000 All dpad buttons up
DS4GAMEPAD_DPAD_UP, // 0001 direction UP
DS4GAMEPAD_DPAD_RIGHT, // 0010 direction RIGHT
DS4GAMEPAD_DPAD_UP_RIGHT, // 0011 direction UP RIGHT
DS4GAMEPAD_DPAD_DOWN, // 0100 direction DOWN
DS4GAMEPAD_DPAD_CENTERED, // 0101 invalid
DS4GAMEPAD_DPAD_DOWN_RIGHT,// 0110 direction DOWN RIGHT
DS4GAMEPAD_DPAD_CENTERED, // 0111 invalid
DS4GAMEPAD_DPAD_LEFT, // 1000 direction LEFT
DS4GAMEPAD_DPAD_UP_LEFT, // 1001 direction UP LEFT
DS4GAMEPAD_DPAD_CENTERED, // 1010 invalid
DS4GAMEPAD_DPAD_CENTERED, // 1011 invalid
DS4GAMEPAD_DPAD_DOWN_LEFT, // 1100 direction DOWN LEFT
DS4GAMEPAD_DPAD_CENTERED, // 1101 invalid
DS4GAMEPAD_DPAD_CENTERED, // 1110 invalid
DS4GAMEPAD_DPAD_CENTERED, // 1111 invalid
Bounce * buttons = new Bounce[NUM_BUTTONS];
Bounce * dpad = new Bounce[NUM_DPAD];
uint8_t dpad_bits = 0;
typedef struct axis_t {
uint16_t adcMin;
uint16_t adcMax;
const uint8_t toMin;
const uint8_t toMax;
} axis_t;
// Set the initial min/max 1/8 away from the ADC min/max.
#define ARDUINO_ADC_RESOLUTION (10)
#define ADC_INITIAL_MIN (1 << (ARDUINO_ADC_RESOLUTION - 3))
#define ADC_INITIAL_MAX ((1 << ARDUINO_ADC_RESOLUTION) - ADC_INITIAL_MIN)
axis_t LeftX = {
ADC_INITIAL_MIN, ADC_INITIAL_MAX, 0, 255
axis_t LeftY = {
ADC_INITIAL_MIN, ADC_INITIAL_MAX, 255, 0
axis_t RightX = {
axis_t RightY = {
axis_t LeftTrigger = {
axis_t RightTrigger = {
// Dynamically determine the pot/ADC limits because my craptastic
// analog sticks have dead zones at the ends.
uint8_t axisRead(int analogPin, struct axis_t &ax)
uint16_t x = analogRead(analogPin);
if (x > ax.adcMax) ax.adcMax = x;
if (x < ax.adcMin) ax.adcMin = x;
return map(x, ax.adcMin, ax.adcMax, ax.toMin, ax.toMax);
// Pin 13 has resistor and LED pulling the pin to ground so it does not work as an
// input. Remove the resistor and/or LED to make pin 13/touch pad button work.
for (int i = 0; i < NUM_BUTTONS; i++) {
buttons[i].attach( BUTTON_PINS[i], INPUT_PULLUP );
for (int i = 0; i < NUM_DPAD; i++) {
dpad[i].attach( DPAD_PINS[i] , INPUT_PULLUP );
#if HAS_DOTSTAR_LED
// Turn off built-in Dotstar RGB LED
strip.begin();
strip.clear();
strip.show();
#endif
// Sends a clean HID report to the host.
DS4Gamepad.begin();
// Update the Bounce instance :
buttons[i].update();
uint8_t button_number = (i > 5) ? i + 2: i;
// Button fell means button pressed
if ( buttons[i].fell() ) {
DS4Gamepad.press(button_number);
else if ( buttons[i].rose() ) {
DS4Gamepad.release(button_number);
dpad[i].update();
if ( dpad[i].fell() ) {
dpad_bits |= (1 << i);
else if ( dpad[i].rose() ) {
dpad_bits &= ~(1 << i);
DS4Gamepad.dPad(DPAD_MAP[dpad_bits]);
DS4Gamepad.rightXAxis(axisRead(0, RightX));
DS4Gamepad.rightYAxis(axisRead(1, RightY));
DS4Gamepad.leftXAxis(axisRead(2, LeftX));
DS4Gamepad.leftYAxis(axisRead(3, LeftY));
uint8_t axis_temp = axisRead(4, LeftTrigger);
DS4Gamepad.leftTrigger(axis_temp);
if (axis_temp < 8)
DS4Gamepad.release(DS4Button_L2);
DS4Gamepad.press(DS4Button_L2);
axis_temp = axisRead(5, RightTrigger);
DS4Gamepad.rightTrigger(axis_temp);
if (axis_temp < 8)
DS4Gamepad.release(DS4Button_R2);
DS4Gamepad.press(DS4Button_R2);
DS4Gamepad.loop();
**It says no scope found on ds4 game pad centred **
** i found the code on git hub **
What is the "it" that says that?
Can you please take a few moments to research how to post code on this forum?
Thanks.
