Hi, I bought a DS18B20 waterproofed temperature sensor recently (actually, it’s 2, but more on this later). The code I have… just doesn’t work.
The first sensor also comes with a DFR24, practically replacing the 4k7 pull-up resistor. The code is found here DS18B20 Temperature Sensor (Arduino Compatible) wiki-DFRobot
The code mentioned is:
#include <OneWire.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
void loop(void) {
float temperature = getTemp();
Serial.println(temperature);
delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++ ) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
However, instead of returning “25C” or something like that, I have -1000.
This prompts me to remove the board, and plug the sensor directly into the breadboard (with the help of more wires and a pull-up resistor).
// Include the libraries we need
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 48
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
void loop(void)
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(sensors.getTempCByIndex(0));
delay(2500);
This one returns -127, which stands for “DEVICE_DISCONNECTED_C”
This makes me (briefly) thinking that the first sensor is defected. However, the second sensor I bought also has the (precisely) the same issue.
I also try the DS18B20.h library this afternoon, the code (at least, with the idea of getting the temperature) is
#include <DS18B20.h>
DS18B20 ds(2);
while (ds.selectNext()) {
Serial.println(ds.getTempC());
It returns 0.00
Also, I have also try to find the address of these sensors (independently, with the one-wire address finder script)
// This sketch looks for 1-wire devices and
// prints their addresses (serial number) to
// the UART, in a format that is useful in Arduino sketches
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
OneWire ds(2); // Connect your 1-wire device to pin 2
void setup(void) {
discoverOneWireDevices();
void discoverOneWireDevices(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
Serial.print("Looking for 1-Wire devices...\n\r");
while(ds.search(addr)) {
Serial.print("\n\rFound \'1-Wire\' device with address:\n\r");
for( i = 0; i < 8; i++) {
Serial.print("0x");
if (addr[i] < 16) {
Serial.print('0');
Serial.print(addr[i], HEX);
if (i < 7) {
Serial.print(", ");
Serial.print("CRC is not valid!\n");
return;
Serial.print("\n\r\n\rThat's it.\r\n");
ds.reset_search();
return;
void loop(void) {
// nothing to see here
This shows nothing for the address, further strengthening the idea that my sensors are, somehow, “not connected” or “disconnected”. I’m pretty much at my wit’s end. Especially that other people, using the very same code, are able to get the temperature.
Do you guys have any idea? Thanks.
