I would like to dimer a neon with an Arduino device by using the following device:
That communicates using the DSI protocol, based on Manchester-coded 8-bit protocol, data rate of 1200 baud, 1 start bit, 8 data bits (dimming value), 4 stop bits (Digital Serial Interface - Wikipedia)
I tried googling it but found nothing...
Someone might suggest the best path for my project?
Can I use libraries like NewSoftSerial or are there more suitable libs?
Hi
I'm working on the same thing, but after my little reasearch i could not find much information... it looks like you have to hardcode the encoding and things like that... same thing on DALI (digital addressable light interface)
but it could be nice if somebody had some information or a lib...
i just started working on the same thing as well. didn't find much on the net either... please tell me if you have some news or developed something as well. i will do the same...
Sorry for the Necro post, but I used to work for Tridonic as their controls specialist for the UK.
Tridonic created the technology, but the information you require will be freely available if you ask them for it.
With DSI, anyone was allowed to send DSI control commands, only the function of responding to them to control a light source was restricted. This was so that only Tridonic could manufacture the ballasts, but anyone could create a compatible control system.
However DSI is a waste of time these days, as there is now a DALI shield available; DSI is functionally identical to using DALI in broadcast mode, only with a higher voltage on the busline.
So in summary, use DALI instead, its an international standard.
