DSM501a(particle sensor) pulseIn on power-adapter not working.
When I connect a power-adapter(DC 9v 1000ma, DC 12v 1000ma) to my arduino, the DSM501a(particle sensor) starts having problems. It seems that some very long blocking starts to take place because of pulseIn.
DSM501a >> Sensor PDF
When looking at the left side (connect to power adapter)
  • Ten samples returned with out timing out
  • Total time to collect the samples was 36.168
  • The duration of all pulseIn added together was 0.764
  • board VCC is 5.091
  • simple benchmark ran after code block shows 756 milliseconds (board running at correct speed)
When looking at the right side (connect to computer via usb)
  • Total time to collect the samples was 1.757
  • The duration of all pulseIn added together was 0.774
  • board VCC is 4.979
Conclusion:
When connected to a power-adapter collecting the samples takes approximately 30x longer, but the total of pulesIn duration are the same, what is causing this issue?
The following code is a simple sketch to illustrate my issue, my program actually uses interrupts and an LCD but the problem is the same.
Full Code
int pin = 3;
// READ VOLTAGE ON VIN
long readVccA() {
  long result;
  // Read 1.1V reference against AVcc
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result = 1126400L / result; // Back-calculate AVcc in mV
  return result;
//GET TEMPTURE OF CPU
double GetTemp(void)
  unsigned int wADC;
  double t;
  // The internal temperature has to be used
  // with the internal reference of 1.1V.
  // Channel 8 can not be selected with
  // the analogRead function yet.
  // Set the internal reference and mux.
  ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));
  ADCSRA |= _BV(ADEN);  // enable the ADC
  delay(20);            // wait for voltages to become stable.
  ADCSRA |= _BV(ADSC);  // Start the ADC
  // Detect end-of-conversion
  // Reading register "ADCW" takes care of how to read ADCL and ADCH.
  wADC = ADCW;
  // The offset of 324.31 could be wrong. It is just an indication.
  t = (wADC - 324.31 ) / 1.22;
  // The returned temperature is in degrees Celcius.
  return (t);
//BENCHMARK
long bench_cnt = 0;
void benchmark() {
  bench_cnt = 0;
  for(bench_cnt = 0; bench_cnt < 1000000; bench_cnt++);
//SETUP APP
  pinMode(pin,INPUT);
  Serial.println( " ------------------------ ");
  Serial.println( " - SETUP_COMPLETED - ");
//ENTERFRAME
long          error      = 0;
int           sample_cnt = 10;
unsigned long sample     = 0;
unsigned long duration   = 0;
float start_time = micros();
for (int i=0; i <= sample_cnt-1; i++){
sample = pulseIn(pin, LOW,60000000); //needs timeout or it does time out
duration = duration + sample;
Serial.print( i+1 ); //removing these serial commands, makes the program run slower, why?
Serial.print( ": " );
Serial.println(float(sample)/1000000,3);
  if( sample==0){
    error++;
} //END
float time_end = (micros()-float(start_time))/1000000;
Serial.print( "Sample Count: ");
Serial.print(  sample_cnt );
Serial.print( " || Time: ");
Serial.print(  time_end,3 );
Serial.print( " || Duration: ");
Serial.print(float(duration)/1000000,3);
Serial.print("  ||  Error: ");
Serial.print(error);
Serial.print("  ||  VCC: ");
Serial.print(float(readVccB())/1000,3);
Serial.print("  ||  TEMP: ");
Serial.println(float(GetTemp()),2);
//CLOCK SPEED IS THE SAME : THIS IS FINE
long unsigned startTime = 0;
long unsigned endTime   = 0;
long unsigned fullTime   = 0;
  startTime = millis();
  benchmark();
  endTime = millis();
  fullTime = endTime - startTime;
  Serial.print(" >> BENCHMARK FOR CLOCK SPEED: ");
  Serial.println(fullTime);
Relevant Code
//ENTERFRAME
long          error      = 0;
  if( sample==0){
    error++;
} //END
  benchmark();
  endTime = millis();
