dtostrf -- doing my head in, or rather coming back with garbage
I have an array, which I split into 12 tokens within my void loop()
strRecordIn = 56.0,0.5,-0,100,830,960,0,400,4100,10240,4095,20
  char strRecordIn[RECORD_IN_ARRAY_SIZE];   // one record in from BMS; every second a new one
  char strRecordOut[RECORD_OUT_ARRAY_SIZE]; // one record out from BMS
If a run a for() through strRecordIn , I see all tokens
I am add some of the values to strRecordOut, like so:
      // create array of BMS values
      int arrayElements = 11;               // number of BMS values (12)
      char *arrValues[arrayElements];       // array holding values
      arrValues[0] = strtok(strRecordIn, ",");
      for (int j = 1; j <=arrayElements; j++) {
        arrValues[j] = strtok(NULL, ",");    // Split string into tokens
      strcat(strRecordOut, clock.dateFormat("d/m/Y H:i:s", dt));        // add delimiter
      for (int i = 0; i <= 3; i++) {         // VLT, AMP, AHR, SOC
        strcat(strRecordOut, ",");           // add delimiter
        strcat(strRecordOut, arrValues[i]);  // add value
      if (intLoopCounter == 50) {            // every 50 records read temperature sensor
        sensors.requestTemperatures();       // get temperatues
        currentTemp = sensors.getTempCByIndex(0); // read 1st temperature sensor
        intLoopCounter = 0;                  // reset
      // here: temp float value, -12.34 (6), 2, buf = 6+\0
      //char charBuf[] = "";
      //dtostrf(currentTemp, 6, 2, charBuf); // convert float to char
      //strcat(strRecordOut, charBuf);       // ad temperature
      strcat(strRecordOut, "22.22");         // ad temperature
      // get field 7 -- ERR error value      // ERR
      strcat(strRecordOut, arrValues[6]);    // add error value
      // get field 12 -- TIM value           // TIM= BMS record count (0-45)
      strcat(strRecordOut, arrValues[11]);   // add received record count
      for (int k = 0; k <=arrayElements; k++) {
        Serial.print(k);
        Serial.print(" ");
        Serial.println(arrValues[k]);
      Serial.println(strRecordOut);
      strRecordIn[0]    = '\0';         // empty array
      strRecordOut[0]   = '\0';         // empty array
      recordInByteCount = 0;            // reset byte counter
When I check the array values, they are all OK (values here do not match the array above; as I am showing output of real values)
0 53.0
1 -13.7
2 -86
3 79
4 835
5 960
6 0
7 400
8 3958
9 1975
10 4095
11 4
08/07/2016 19:56:47,53.0,-13.7,-86,79,22.22,0,4 // strRecordOut
Now the interesting part. when I change this section
to:
which changes the temperature float value to char, I l no longer have access to array value 11, and the output is like so:
0 52.9
1 -35.3
2 -88
3 78
4 833
5 960
6 0
7 400
8 3742
9 12616
10 4095
11 ™ê
08/07/2016 20:02:48,52.9,-35.3,-88,78, 24.13,0,™ê
Why on earth does it kill that last value? Any help/hint appreciated.
Also, the temperature value 24.13 has a space in front of it. Is there an easy way to get rid of it?
You only have eleven elements in your array
I don't know if it's the answer to the problem, because of the lack of compilable code which is against forum rules...
But I do spot
Which will just give you a char names charBuf with size 1. Because "" has length 1.
AWOL:
Spot on!
The value of another set of eyes... I was sitting over ti for 3 hours :o
Thank you very much!
Fixed the other error as well? Because now you have a memory overflow...
As a rule-of-thumb, I always pay particular attention to the presence of "<=" in for loops where arrays are concerned.
The empty string mentioned above is also worth a closer look.
septillion:
I read "compatible" and was wondering??? However, compilable you said... which is difficult as the loop is receiving data on the serial port, hence, my description.
dtostrf 'blows' up the char array to 6 ([-]dd.dd = 6)
AWOL:
See above... that's how I understand it works. Did a strlen(charBuf) before and after dtostrf()
septillion:
See above as well... but I am not certiain.
The output is now correct:
0 52.9
1 -15.0
2 -101
3 75
4 834
5 960
6 0
7 400
8 3945
9 10846
10 4095
11 22
08/07/2016 20:28:54,52.9,-15.0,-101,75, 24.25,0,22
Something is likely to blow up, but it isn't your array.
MaxG:
A discribtion is good but also add the full code OR make a simplyfied exaple with the same error. For example, instead of working on receiving data use fixed data that represents it. A lot of times the error isn't in the snippet. Because for example the error is due to a variable declaration or an error in the receiving part. Debugging snippets is just hard.
MaxG:
Nope, it does not. All var lengths are set on declaration. A variable can't grow. You declared it with size 1 so it will always be size 1.
This time you're probably lucky and the memory of &charBuf+1 isn't used or not critical. But you do overflow :wink:
septillion:
a) A discribtion is good but also add the full code OR make a simplyfied exaple with the same error.
b) Nope, it does not. All var lengths are set on declaration. A variable can't grow. You declared it with size 1 so it will always be size 1.
c) This time you're probably lucky and the memory of &charBuf+1 isn't used or not critical. But you do overflow :wink:
Thanks again :slight_smile:
a) understood
b) you're right
c) most likely
changed is to
char charBuf[7];
MaxG:
changed is to
char charBuf[7];
That's better. Be aware that a char of 7 limits you to values of 999,99. Any higher will still overflow.
