Dual 3.5" LCD screens displaying different content?
Hello i have a bunch of 3'5" LCD screens i got a while back. But never had a chance to use them now. I was thinking of using two of them to display different content on them. However Being that both LCD screens take the same pin out is almost all the arduino uno pins besides the A5 and D0 and D1 which are free. I been looking around online and nothing has dual screens like this screen i got them from ebay here is a link Here I have been seeing that i can have multiple of everything that is taking put by SPI. I just need to change the SS pins to a different type of pin Wondering if this is possible?
The pinout is set in sketch
//Technical support:goodtft@163.com
// Breakout/Arduino UNO pin usage:
// LCD Data Bit :   7   6   5   4   3   2   1   0
// Uno dig. pin :   7   6   5   4   3   2   9   8
// Uno port/pin : PD7 PD6 PD5 PD4 PD3 PD2 PB1 PB0
// Mega dig. pin:  29  28  27  26  25  24  23  22
#define LCD_RD   A0
#define LCD_WR   A1
#define LCD_RS   A2
#define LCD_CS   A3
#define LCD_REST A4
#define WR_MASK B00000010
#define RS_MASK B00000100
void Lcd_Writ_Bus(unsigned char d)
  PORTD = (PORTD & B00000011) | ((d) & B11111100);
  PORTB = (PORTB & B11111100) | ((d) & B00000011);
  PORTC &= ~WR_MASK;
  PORTC|=  WR_MASK;
void Lcd_Write_Com(unsigned char VH)
   PORTC &= ~RS_MASK;
  Lcd_Writ_Bus(VH);
void Lcd_Write_Data(unsigned char VH)
  PORTC |= RS_MASK;
  Lcd_Writ_Bus(VH);
void Lcd_Write_Com_Data(unsigned char com,unsigned char dat)
  Lcd_Write_Com(com);
  Lcd_Write_Data(dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
        Lcd_Write_Com(0x2a);
	Lcd_Write_Data(x1>>8);
	Lcd_Write_Data(x1);
	Lcd_Write_Data(x2>>8);
	Lcd_Write_Data(x2);
        Lcd_Write_Com(0x2b);
	Lcd_Write_Data(y1>>8);
	Lcd_Write_Data(y1);
	Lcd_Write_Data(y2>>8);
	Lcd_Write_Data(y2);
	Lcd_Write_Com(0x2c);
void Lcd_Init(void)
  digitalWrite(LCD_REST,HIGH);
  delay(5);
  digitalWrite(LCD_REST,LOW);
  delay(15);
  delay(15);
  digitalWrite(LCD_CS,HIGH);
  digitalWrite(LCD_WR,HIGH);
  digitalWrite(LCD_CS,LOW);  //CS
Lcd_Write_Com(0x11);
  delay(20);
  Lcd_Write_Com(0xD0);
  Lcd_Write_Data(0x07);
  Lcd_Write_Data(0x42);
  Lcd_Write_Data(0x18);
  Lcd_Write_Com(0xD1);
  Lcd_Write_Data(0x00);
  Lcd_Write_Data(0x07);//07
  Lcd_Write_Data(0x10);
  Lcd_Write_Com(0xD2);
  Lcd_Write_Data(0x01);
  Lcd_Write_Data(0x02);
  Lcd_Write_Com(0xC0);
  Lcd_Write_Data(0x3B);
  Lcd_Write_Data(0x11);
  Lcd_Write_Com(0xC5);
  Lcd_Write_Data(0x03);
  Lcd_Write_Com(0x36);
  Lcd_Write_Data(0x0A);
  Lcd_Write_Com(0x3A);
  Lcd_Write_Data(0x55);
  Lcd_Write_Com(0x2A);
  Lcd_Write_Data(0x3F);
  Lcd_Write_Com(0x2B);
  Lcd_Write_Data(0xE0);
  delay(120);
  Lcd_Write_Com(0x29);
  Lcd_Write_Com(0x002c);
void H_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
  unsigned int i,j;
  Lcd_Write_Com(0x02c); //write_memory_start
  digitalWrite(LCD_RS,HIGH);
  l=l+x;
  Address_set(x,y,l,y);
  j=l*2;
  for(i=1;i<=j;i++)
    Lcd_Write_Data(c);
void V_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
  unsigned int i,j;
  l=l+y;
  Address_set(x,y,x,l);
  j=l*2;
  for(i=1;i<=j;i++)
    Lcd_Write_Data(c);
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
  H_line(x  , y  , w, c);
  H_line(x  , y+h, w, c);
  V_line(x  , y  , h, c);
  V_line(x+w, y  , h, c);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
  unsigned int i;
  for(i=0;i<h;i++)
    H_line(x  , y+i, w, c);
int RGB(int r,int g,int b)
{return r << 16 | g << 8 | b;
void LCD_Clear(unsigned int j)
  unsigned int i,m;
 Address_set(0,0,320,480);
  //Lcd_Write_Com(0x02c); //write_memory_start
  //digitalWrite(LCD_RS,HIGH);
  for(i=0;i<320;i++)
    for(m=0;m<480;m++)
      Lcd_Write_Data(j>>8);
      Lcd_Write_Data(j);
  for(int p=0;p<10;p++)
    pinMode(p,OUTPUT);
  pinMode(A0,OUTPUT);
  pinMode(A1,OUTPUT);
  pinMode(A2,OUTPUT);
  pinMode(A3,OUTPUT);
  pinMode(A4,OUTPUT);
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, HIGH);
  digitalWrite(A3, HIGH);
  digitalWrite(A4, HIGH);
  Lcd_Init();
 //LCD_Clear(0xf800);
   LCD_Clear(0xf800);
   LCD_Clear(0x07E0);
   LCD_Clear(0x001F);
  for(int i=0;i<1000;i++)
    Rect(random(300),random(300),random(300),random(300),random(65535)); // rectangle at x, y, with, hight, color
//  LCD_Clear(0xf800);
I really need some help on this project can someone please help me and guide me to what i need to do next? Thank you.
Modify your post please and fix the link.
Did you know that the link can be shortened ? https://www.ebay.com/itm/282634901590
(deleted)
Thank you spycatcher2k I'm able now to see both screens different text with changing the A3 on the second screen to A5 and it is working that is a free pin and I'm able to see it working. Thank you.
