Dual authentication door lock
Hey guys . in my previous post which i had no response i hard a challenge with my project where i used a both an RFID and a FINGERPRINT module to open and Electromagnetic lock. the idea is to be able to enroll(fingerprint), delete(fingerprint) and authenticate fingerprint and rfid card.
i ended up using switch case with with 4 cases.
without the codes for for authentication, enrollment and deletion, the void loop() function runs completely but when i add the authentication function to the loop it does not run. at the start of the int authenticate() function i added a message to be displayed in the LCD and it does but does not go beyond that. please here is the code bellow i really need help figuring this out as i am running out of time.
please go easy on me, i am only a beginner.
when i place a lcd message after the functions the message is displayed without execution of loop.
#include <Wire.h>
#include <Adafruit_Fingerprint.h>
#include <MFRC522.h>
#include <Keypad.h>
#include <SoftwareSerial.h>
// Initialize the fingerprint module
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// Initialize the RFID module
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
// Initialize the LCD i2c
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Initialize the keypad
const byte ROWS = 4;
const byte COLS = 3;
char hexakeys[ROWS][COLS] =
      {'1', '2', '3'},
      {'4', '5', '6'},
      {'7', '8', '9'},
      {'*', '0', '#'}
byte pinRowPins[ROWS] = {8, 7, 6, 5};
byte pinColPins[COLS] = {A0, A1, A2};
Keypad Mykeys = Keypad(makeKeymap(hexakeys), pinRowPins, pinColPins, ROWS, COLS);
// Constants
const int PIN_LENGTH = 5;
const int AUTH_OPTION = 1;
const int ENROLL_OPTION = 2;
const int DELETE_OPTION = 3;
// Variables
int menuOption = 0;
int subMenuOption = 0;
String pinInput = "";
int state;
int EMLock =A0;
int FPrint =A1;
      pinMode(EMLock, OUTPUT);
     pinMode(A1, OUTPUT);
     pinMode(A2, OUTPUT);
      lcd.init();lcd.begin(16, 2);
      lcd.backlight();
      //Initialize the RFID module
      SPI.begin(); // Initiate SPI bus
      mfrc522.PCD_Init();
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print("1. Auth 2. Enroll,  ");
      lcd.setCursor(0, 1);
      lcd.print("3. Delete      ");
        Serial.begin(9600); // Initiate a serial communication
while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("fingertest");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  finger.getTemplateCount();
  Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  Serial.println("Waiting for valid finger...");
    {      // Check for keypad input
      char getkey = Mykeys.getKey();
      if (getkey)
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.print(getkey);
          switch (getkey)
                  case '1': //case for authentiication which does not execute
                    menuOption = AUTH_OPTION;
                   authenticate();
                    delay(2000);
                    resetMenu();
                  case '2':
                    menuOption = ENROLL_OPTION;
                  showSubMenu();
                  case '3':
                    menuOption = DELETE_OPTION;
                  showSubMenu();
                  case '*':
                  resetMenu();
                    default:
                      if (subMenuOption != 0)
                        {// Collect Pin
                           if (pinInput.length()< PIN_LENGTH)
                             { lcd.setCursor(pinInput.length(), 1);
                                  lcd.print('*'); delay(200);
                                  pinInput += getkey;
                              //Check if PIN input
                           if (pinInput.length()==PIN_LENGTH)
                                processPINInput();
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerFastSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
lcd.clear();
   lcd.setCursor(2,0);
   lcd.println("INVALID BIO-ID  ");
   lcd.setCursor(2,1);
   lcd.println("TRY AGAIN  ");
   state = HIGH;
   return p;
  else {
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() //function which test for fingerprint
  if (p != FINGERPRINT_OK)  return -1;
  // found a match!
 lcd.clear();
digitalWrite(FPrint, HIGH);
  lcd.setCursor(2,0);
   lcd.println("VALID BIO-ID     ");
   lcd.setCursor(2,1);
   lcd.println("SCAN RFID       ");
   state = HIGH;
void ScanRFIDCard() //function which checks the RFID card
     if ( ! mfrc522.PICC_IsNewCardPresent())
         return;
         //Select one of the cards
     if ( ! mfrc522.PICC_ReadCardSerial())
         return;
//Show UID on serial monitor
Serial.print("UID tag :");String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
 content.concat( String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message: ");
content.toUpperCase();
if ((content.substring(1) == "A3 38 D7 0A") && (state==HIGH))
   digitalWrite(EMLock, HIGH);
   lcd.clear();
   lcd.setCursor(1,0);
   lcd.println("ACCESS GRANTED     ");
   lcd.setCursor(2,1);
   lcd.println("WELCOME JINUI     ");
   delay(5000);
   digitalWrite(EMLock, LOW);
   digitalWrite(5, LOW);
   lcd.clear();
   lcd.setCursor(1,0);
   lcd.println("  TIME OUT!     ");
   lcd.setCursor(2,1);
   lcd.println("START OVER     ");
   state=LOW;
else if ((content.substring(1) == "A3 38 D7 0A") && (state==LOW))
   lcd.clear();
   lcd.setCursor(1,0);
   lcd.println("INVALID ORDER   ");
   lcd.setCursor(1,1);
   lcd.println(" FINGER FIRST   ");
else if ((content.substring(1) != "A3 38 D7 0A") && (state==LOW))
   lcd.clear();
   lcd.setCursor(1,0);
   lcd.setCursor(1,1);
else if ((content.substring(1) != "A3 38 D7 0A") && (state==HIGH))
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.println("UNAUTHORIZED ID  ");
   lcd.setCursor(1,1);
   lcd.println("ACCESS DENIED!  ");
   char waitForUserInput()
      while (true)
             if (getkey)
                  return getkey;
 void authenticate() //the two functions are combined here before being moved to the case
    {// Display appropriate messages on LCD
      lcd.clear();
      lcd.print("hope on this one");
      getFingerprintIDez();
      delay(50);    //don't ned to run this at full speed.
      ScanRFIDCard();
      delay(2000);
      resetMenu();
void enroll()
      lcd.clear();
      lcd.print("enrolling");
      lcd.print("yk");
      delay(2000);
      resetMenu();
void deleteFingerprint()
      digitalWrite(A2,HIGH);
      delay(200);
      digitalWrite(A2,LOW);
      delay(2000);
      resetMenu();
    void showSubMenu()
      lcd.clear();
      lcd.print("INPUT PIN: ");
      subMenuOption = menuOption;
      menuOption = 0;
      pinInput = "";
void resetMenu()
      lcd.clear();
      lcd.print("1. Auth, 2. Enroll,");
        menuOption = 0;
        subMenuOption = 0;
        pinInput = "";
void processPINInput()
    {    //Check PIN for respective options
      if (subMenuOption == ENROLL_OPTION)
          if (pinInput == "45456")
              enroll();
            lcd.clear();
            lcd.print("ACCESS DENIED!");
            delay(2000);
            resetMenu();
      else if (subMenuOption == DELETE_OPTION)
               if (pinInput == "56564")
                   deleteFingerprint();
                    lcd.clear();
                    lcd.print("ACESS DENIED!");
                    delay(2000);
                    resetMenu();
Your using A0 .. A2 for two different purposes; this might cause problems.
and
int EMLock = A0;
int FPrint = A1;
that has been checked but it still does not execute. i discovered that just the int ScanRFIDCard() function executes but the int getFingerprintIDez() function does not and the int ScanRFIDCard() function depends on int getFingerprintIDez() to execute...
