dual h bridge shield help
heres what i made:
http://s1019.photobucket.com/albums/af315/frostin2k8/?action=view&current=hbridgeshield.jpg
will this work by powering the arduino from the shield?
Edit: I seen a cool little laser project. Spirograph. I be using 3 12v dc fans.
I am not sure what you are asking?
This is just a PCB layout, without knowing what ICs you are using or how you are wiring it up I can't tell if it will work.
I am not clear about the "powering the arduino from the shield" bit. Generally you don't do this.
Its the 16 pin h bridge commonly found on the playground. so id need to step up the voltage and take out the regulator? i have the eagle board file if you want to look at it. i didnt make a sch
No if you need more voltage than 5V then take it from an external power supply like a wall wart. For things like motors it is advisable to use an external supply anyway. See:- http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html and http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
K. think ill just use a 12v wall wart to power the arduino and shield. Looks luke I can just take the power connector jack off the pcb and regulator. Looks like i canuse the 3.3v power for the laser diode. But my question is.. why on a driver schematic is the lm317 backwards? Thought Vin would be the left pin/prong, adjust in middle and Vout on the right pin...?
i only need the motors run one way. i could harvest steppers. if i only go one direction ill just need one chip if the current can handle it from the motors correct?basically high/low all i need. also im wanting to manually control the motors via pots. so could i just wire in a pot off the motor by itself and if i wanted the arduino to do a custom rotations, turn the pot down and power on tne arduino?
In that case you only need half of the H bridge, connect one end of the motor to a power rail (+ or -) and the other end to one of the outputs of the H bridge.
woo You just hit a whole other lode of stuff. What do you men by control, speed?
No pots usually take only a very small amount of current, if you connect a regular pot to a regular motor you will fry the pot.
Do say what you want to do please.
I want to manuually control each motor with a knob. then be able if i wanted to to have the arduino do it with a written program turning on/off the motors via delay. Theres a guy who used a PIC but id rather use an arduino. and you see my question for the laser circuit? shouldnt voltage flow only one way through a regulator not backwards? heres the link: www.instructables.com/id/Laser-show-for-poor-man/
To control a DC motor with a pot, you'll need to wire the pot to 5V, GND, and one of the Arduino's analog inputs. You can then write code to read a value between 0 and 1023 from the analog pin, based on the position of the pot.
To convert this into motor speed control, you will take that value, divide it by 4 (to convert it to 0-255, the range of values for PWM'ing a motor) and analogWrite it to the port that your motor driver is connected to. Make sure you're using a PWM-capable port for that, they are marked as such on the Arduino PCB.
should i put in any capacitors? little better picture of board: http://img710.imageshack.us/i/hbridgeshield.jpg/
Ok I think I'm understanding more now. Basically wire 3 pots to 3 pwm pins. I could then add a button or switch for the arduino to automatically control them ( puttin the button in high/low) if high then it will automatically do a routine, if low I could manually do with the pots. Am I correct?
