Dual input Dual Output PID Controller
Recently I discovered the library "ArduPID" which will allow me to use a PID controller for one variable input. I am planning on using it for a TVC rocket but can't figure out how to run it for two variables at once. Is this possible?
Here is the example code provided by the library:
#include "ArduPID.h"
ArduPID myController;
double setpoint = 512;
double input;
double output;
double p = 0.5;
double i = 0.2;
double d = 0.1;
  myController.begin(&input, &output, &setpoint, p, i, d);
  // myController.reverse()               // Uncomment if controller output is "reversed"
  // myController.setSampleTime(10);      // OPTIONAL - will ensure at least 10ms have past between successful compute() calls
  myController.setOutputLimits(-30, 30);
  //myController.setBias(255.0 / 2.0);
  myController.setWindUpLimits(-10, 10); // Groth bounds for the integral term to prevent integral wind-up
  myController.start();
  input = analogRead(A0); // Replace with sensor feedback
  myController.compute();
  myController.debug(&Serial, "myController", PRINT_INPUT    | // Can include or comment out any of these terms to print
                                              PRINT_OUTPUT   | // in the Serial plotter
                                              PRINT_SETPOINT |
                                              PRINT_BIAS     |
                                              PRINT_P        |
                                              PRINT_I        |
                                              PRINT_D);
  analogWrite(3, output); // Replace with plant control signal
Also here is the function code that I found in the library:
void ArduPID::begin(double* _input,
                  double* _output,
                  double* _setpoint,
                  const double& _p,
                  const double& _i,
                  const double& _d,
                  const pOn& _pOn,
                  const dir& _direction,
                  const unsigned int& _minSamplePeriodMs,
                  const double& _bias)
  input    = _input;
  output   = _output;
  setpoint = _setpoint;
  setCoefficients(_p, _i, _d);
  setPOn(_pOn);
  setBias(_bias);
  setDirection(_direction);
  setSampleTime(_minSamplePeriodMs);
  reset();
  start();
void ArduPID::start()
  if (modeType != ON)
    modeType = ON;
    reset();
void ArduPID::reset()
  curError    = 0;
  curSetpoint = 0;
  curInput    = 0;
  lastError    = 0;
  lastSetpoint = 0;
  lastInput    = 0;
  pOut = 0;
  iOut = 0;
  dOut = 0;
  timer.start();
void ArduPID::stop()
  if (modeType != OFF)
    modeType = OFF;
void ArduPID::compute()
  if (timer.fire() && modeType == ON)
    kp = pIn;
    ki = iIn * (timer.timeDiff / 1000.0);
    kd = dIn / (timer.timeDiff / 1000.0);
    if (direction == BACKWARD)
      kp *= -1;
      ki *= -1;
      kd *= -1;
    lastInput    = curInput;
    lastSetpoint = curSetpoint;
    lastError    = curError;
    curInput    = *input;
    curSetpoint = *setpoint;
    curError    = curSetpoint - curInput;
    double dInput = *input - lastInput;
    if (pOnType == P_ON_E)
      pOut = kp * curError;
    else if (pOnType == P_ON_M)
      pOut = -kp * dInput;
    iOut += (ki * ((curError + lastError) / 2.0)); // Trapezoidal integration
    iOut = constrain(iOut, windupMin, windupMax);  // Prevent integral windup
    dOut = -kd * dInput; // Derrivative on measurement
    double newOutput = bias + pOut + iOut + dOut;
    newOutput        = constrain(newOutput, outputMin, outputMax);
    *output          = newOutput;
void ArduPID::setOutputLimits(const double& min, const double& max)
  if (max > min)
    outputMax = max;
    outputMin = min;
    if (modeType == ON)
      *output = constrain(*output, outputMin, outputMax);
void ArduPID::setWindUpLimits(const double& min, const double& max)
  if (max > min)
    windupMax = max;
    windupMin = min;
void ArduPID::setDeadBand(const double& min, const double& max)
  if (max >= min)
    deadBandMax = max;
    deadBandMin = min;
void ArduPID::setPOn(const pOn& _pOn)
  pOnType = _pOn;
void ArduPID::setBias(const double& _bias)
  bias = _bias;
void ArduPID::setCoefficients(const double& _p, const double& _i, const double& _d)
  if (_p >= 0 && _i >= 0 && _d >= 0)
    pIn = _p;
    iIn = _i;
    dIn = _d;
void ArduPID::setDirection(const dir& _direction)
  direction = _direction;
  if (modeType == ON)
    reset();
void ArduPID::reverse()
  if (direction == FORWARD)
    direction = BACKWARD;
  else if (direction == BACKWARD)
    direction = FORWARD;
  if (modeType == ON)
    reset();
void ArduPID::setSampleTime(const unsigned int& _minSamplePeriodMs)
  timer.begin(_minSamplePeriodMs);
double ArduPID::B()
  return bias;
double ArduPID::P()
  return pOut;
double ArduPID::I()
  return iOut;
double ArduPID::D()
  return dOut;
void ArduPID::debug(Stream* stream, const char* controllerName, const byte& mask)
  if (mask & PRINT_INPUT)
    stream->print(controllerName);
    stream->print("_input ");
  if (mask & PRINT_OUTPUT)
    stream->print("_output ");
  if (mask & PRINT_SETPOINT)
    stream->print("_setpoint ");
  if (mask & PRINT_BIAS)
    stream->print("_bias ");
  if (mask & PRINT_P)
    stream->print("_P ");
  if (mask & PRINT_I)
    stream->print("_I ");
  if (mask & PRINT_D)
    stream->print("_D ");
  stream->println();
    stream->print(*input);
    stream->print(" ");
    stream->print(*output);
    stream->print(" ");
    stream->print(*setpoint);
    stream->print(" ");
    stream->print(bias);
    stream->print(" ");
  if (mask & PRINT_P)
    stream->print(pOut);
    stream->print(" ");
  if (mask & PRINT_I)
    stream->print(iOut);
    stream->print(" ");
  if (mask & PRINT_D)
    stream->print(dOut);
    stream->print(" ");
  stream->println();
Any help would be greatly appreciated!
Why not 2 PID?
What is your controlled system?
From my understanding, I only see one input variable and don't see how to make another. My controlled system is the y and z angles coming out of the bno055 meant to control two servos.
Make two ArduPID controllers myController1 and myController2?
Yeah I think that should work, I'll give it a shot with my angles later and let you know. Thanks!
