dual laser up down counter
PLEASE HELP! I have been working on this project for weeks and I am struggling. I got it to work with 4029 ics, now I’m trying to make it work with arduino. Two LDR’s are hooked to A0 and A1, a laser is pointed at each. When some walks through the lasers a breaks the beams I want the arduino to count one. If the person were to break ldr1 prior to ldr2, it would add one to a people variable and if a person were to break ldr2 prior to ldr1, it would subtract one. This would essentially be used to count how many people are in a room and display the “People: #” on a LCD. I don’t have much code for this, really just introducing the variables. Please help, thank you!
///////////////////////////////////////////////////LCD
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
///////////////////////////////////////////////////GLOBAL
  //LDR inputs and values
    const int ldr1 = A0;
    const int ldr2 = A1;
    int sens1 = 0;
    int sens2 = 0;
  //value of people in the room
    int people = 0;
///////////////////////////////////////////////////SETUP
 void setup() { //OPEN VOID SETUP
   lcd.begin(16,2);
 }//CLOSE VOID SETUP
void loop() { //OPEN VOID LOOP
  //set up display to show People: 0 on line 2
    lcd.setCursor(0, 1);
    lcd.print("People:");
    lcd.print(people);
    sens1 = map(analogRead(ldr1), 0, 1023,0,1);
    sens2 = map(analogRead(ldr2), 0, 1023,0,1);
  if(sens1 < 300){
    people = people++; }
   else if(sens2 < 300) {
     people = people--; }
  Serial.print(ldr1);
    Serial.println("\t");
  Serial.print(ldr2);
  Serial.print(sens1);
  Serial.print(sens2);
} //OPEN VOID LOOP
