Dual LDO to generate 5V on Arduino UNO
Does anyone know why two DC-DC converters are used to make 5V from Vin on the Arduino UNO? I've seen another thread that said it was an "alternate parts" selection (not clear from the schematic), but Vin (which is the net straight after D1) is on two devices. One is clearly the MC33269 LDO in the ST package, but the other is an 8 pin device labeled 103. Is that really a second regulator (the MC33269 in the D package)? What is the point?
SteelyD:
You mean the 3.3V reg?
You might be mixing up more than one thing.
There is a 5volt regulator and a 3.3volt regulator.
The 3.3volt regulator on my board is close to the electrolytic caps, and has 5 pins.
There is also an 8-pin LM358 double opamp in that area.
But an 8-pin "103" is likely a 4x10k resistor array.
Leo..
aarg:
If you look at the UNO schematic (https://www.arduino.cc/en/uploads/Main/arduino-uno-schematic.pdf), in the upper right there are two regulators between Vin and +5V, that’s what I was talking about. I don’t understand the purpose.
I see the 3V3 regulator labeled as U2 on the left-center. Not talking about that.
The 2 regulators allow for picking of one or the other, either will fit on the pads on the board.
