Hi Guys
New to this forum and a fairly Noob to programming to.
I am having an issue with some code. what i am trying to achieve is have two separate rotary encoders change two separate values on an 8 x 2 LCD.
I have found Ralph Bacon's Interrupt code and it works almost as i want it to but i have an issue where one encoder wont work unless i turn the other one click back or forward. Then the first encoder works fine, but if i try the second encoder, it wont work unless i do the same again to the first.
Here is the full code so far and i am currently using an UNO but will migrate to a MICRO for the final project.
would really appreciate any help and very keen to learn more about programming correctly.
// EEPROM Setup
#include <EEPROM.h>
// LCD Setup
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8); // initialize the libary with the interface pins
//ENCODER Setup
//MM Encoder
const int MMPinA = 3; // Used for generating interrupts using CLK signal
const int MMPinB = 4; // Used for reading DT signal
int MMlastCount; // Keep track of last rotary value
float MMdecLastCount; // sets last count number to a decimal
float MMcalc; // Sets calculated number to a decimal
volatile int MMvirtualPosition = EEPROM.read(1); // Updated by the ISR (Interrupt Service Routine)
//SPD Encoder
const int SPDPinA = 2; // Used for generating interrupts using CLK signal
const int SPDPinB = 5; // Used for reading DT signal
int SPDlastCount; // Keep track of last rotary value
float SPDdecLastCount; // sets last count number to a decimal
float SPDcalc; // Sets calculated number to a decimal
volatile int SPDvirtualPosition = EEPROM.read(2); // Updated by the ISR (Interrupt Service Routine)
//Safety Switch Setup
const int safetyPin = A0; //Set Safety Pin to A0
int safeVal = 0; // Set initial value to 0
//Stepper Motor Setup
int motorEnable = 0; // Set stepper motor enable pin to Digital pin 0
int motorStep = 7; // Set stepper motor Step pin to Digital pin 7
int motorDir = 6; // Set stepper motor Direction pin to Digital pin 6
//Manual/Auto Switch Setup
const int manAutoPin = A1; //Ser Manual Auto pin to A1
int manAutoVal = 0; //Set initial value to 0
//INTERUPT Setup
void isr1 ()
{ //MM Setup
static unsigned long MMlastInterruptTime = 0;
unsigned long MMinterruptTime = millis();
if (MMinterruptTime - MMlastInterruptTime > 5) // If interrupts come faster than 5ms, assume it's a bounce and ignore
if (digitalRead(MMPinB) == LOW)
MMvirtualPosition-- ;
MMvirtualPosition++ ;
MMvirtualPosition = min(250, max(0, MMvirtualPosition)); // Restrict value from 0 to +250
MMlastInterruptTime = MMinterruptTime; // Keep track of when we were here last (no more than every 5ms)
void isr2 ()
{ //SPD Setup
static unsigned long SPDlastInterruptTime = 0;
unsigned long SPDinterruptTime = millis();
if (SPDinterruptTime - SPDlastInterruptTime > 5) // If interrupts come faster than 5ms, assume it's a bounce and ignore
if (digitalRead(SPDPinB) == LOW)
SPDvirtualPosition-- ;
SPDvirtualPosition++ ;
SPDvirtualPosition = min(250, max(0, SPDvirtualPosition)); // Restrict value from 0 to +250
SPDlastInterruptTime = SPDinterruptTime; // Keep track of when we were here last (no more than every 5ms)
//EPPROM setup
EEPROM.read (1);
MMvirtualPosition = EEPROM.read (1);
EEPROM.read (2);
SPDvirtualPosition = EEPROM.read (2);
// LCD Setup
lcd.begin(8,2); //set the LCD's number of columns and rows
lcd.setCursor(0, 0); //Set cursor to column 0, row 0
lcd.print("INTRFLUX"); //Display INTRFLUX on first line
lcd.setCursor(1, 1); //Set cursor to column 1, row 1
lcd.print("SWF 25"); //Display SWF 25 on Second line
delay(3000); //Display above lines for 3 seconds
lcd.clear(); //Clear the LCD
delay(2000); //Wait 2 seconds before going to loop
//Encoder Setup
//####################Serial.begin(9600); // Just whilst we debug, view output on serial monitor
//Sets the encoder pins
pinMode(MMPinA, INPUT); // Rotary pulses are INPUTs
pinMode(MMPinB, INPUT);
attachInterrupt(digitalPinToInterrupt(MMPinA), isr1, LOW); // Attach the routine to service the interrupts
pinMode(SPDPinA, INPUT); // Rotary pulses are INPUTs
pinMode(SPDPinB, INPUT);
attachInterrupt(digitalPinToInterrupt(SPDPinA), isr2, LOW); // Attach the routine to service the interrupts
//###################Serial.println("Start"); // Ready to go!
//Safety Pin Setup
pinMode (safetyPin, INPUT); //Set safety pin to an input
digitalWrite (A0, HIGH); //Set safety pin HIGH
//Manual Auto Switch Setup
pinMode (manAutoPin, INPUT);
digitalWrite (A1, HIGH);
void loop()//###DISPLAY SCREEN###
safeVal = digitalRead(A0);
//Serial.print(safeVal);
//Safety Switch
if (safeVal != 1) //If Safety Pin A0 is Low change screen to COVER OPEN
//lcd.clear();
lcd.setCursor (0,0);
lcd.print(" Cover ");
lcd.setCursor(0,1);
lcd.print(" Open ");
delay(100);
//Encoder
//LCD
lcd.setCursor(1, 0);
lcd.print("MM:");
lcd.setCursor(0, 1);
lcd.print("Spd:");
lcd.setCursor(4, 0);
if (MMcalc < 10) lcd.print(" ");
lcd.print(MMcalc,1); //from encoder calcMM value
lcd.setCursor(4, 1);
if (SPDcalc < 10) lcd.print(" ");
lcd.print(SPDcalc,1); //from encoderSPD value // If the current rotary switch position has changed then update everything
MMlastCount = MMvirtualPosition ; // Keep track of this new value
MMdecLastCount = MMvirtualPosition;
MMcalc = (MMdecLastCount/10);
EEPROM.write (1, MMvirtualPosition); //Save number to EEPROM position 1
SPDlastCount = SPDvirtualPosition ; // Keep track of this new value
SPDdecLastCount = SPDvirtualPosition;
SPDcalc = (SPDdecLastCount/10);
EEPROM.write (2, SPDvirtualPosition); //Save number to EEPROM position 1
