Dual SoftwareSerial on ATTINY85
I am looking to set up an ATTINY85 chip with two softwareserial
One softwareserial communicates with RXTX of arduino uno board
Second software serial communicates with ESP8266 chip
I am using below sketch:
#include <SoftwareSerial.h>
SoftwareSerial arduino(0,1); //rx,tx
SoftwareSerial wifi(2,3); //rx,tx
arduino.begin(9600);
arduino.println("ATTINY85 Ready");
wifi.begin(9600);
wifi.listen();
while (wifi.available() > 0) {
char inByte = wifi.read();
arduino.write(inByte);
arduino.listen();
while (arduino.available() > 0) {
char inByte = arduino.read();
wifi.write(inByte);
I have changed the baudrate on the ESP8266 to 9600
When I test this I get ATTINY85 Ready in my serial monitor.
I connect power to ESP8266 and it does send serial connection data however it is garbled
When I connect the ESP8266 directly to the arduino it shows correct connection information at 9600 baud (not garbled)
Somewhere in the receiving of the serial data from the ESP to sending it out from the ATTINY85 it is getting garbled.
Anyone know why this is happening and a possible patch for the sketch to remedy it?
wifi.write(inByte);
What if data is still incoming when this code starts running? It receives one character - and it's still receiving more - and then this code starts executing, and you try to write to another software serial instance. But it's still receiving data, and you're using software serial.
You can't send while receiving when using software serial.
Have you considered the ATTiny841? It's got 2 hardware serials, as well as 6 PWM pins (11 IO pins + power ground reset in SOIC-14 package), and they're about the same price as attiny84's - my ATTiny core supports it, so you can program it through the IDE and all. Only sad thing is there's no DIP version, only SMD packages. There's also the tiny1634 with two hardware serial ports, more pins, and more memory.
