Dual stepper motor project: issues with independent speed control and counterclockwise motion
Hey, I'm working on a project that will allow me to control two NEMA 17 stepper motors using a joystick. These two motors can change direction and have variable speed based on the input of the controller. This code works well but I'm having trouble on two key issues.
First : My motors are supposed to be able to change directions, I have attempted to switch the step value for counterclockwise movement from positive 8 to negative 8 in these two lines of code stepper.move(8); , stepper1.move(8); , but when I do the program breaks, causing the motors and values displayed on the Serial monitor to freeze.
Second : The motors are supposed to take their RPM values from adjJoystick and adjJoystick1 , which take their numbers from Analog pin 1 and 0. But for some reason when both motors are activated they lose the ability to adjust their speed independently. [Note: after doing some testing I found that the DIRE, DIRE1, STEP, and STEP1 pins are not processed by the boards. If that is the problem would somebody be able to explain how to fix that?]
[code]
#include <Arduino.h>
#include "A4988.h" // Defining the A4988 Library
const int SW_pin = 8; // digital pin connected to switch output
const int  Y_pin = 0; // analog pin connected to X output
const int  X_pin = 1; // analog pin connected to Y output
int Step =    3; //  Step of stepper motor driver
int Dire  =   2; //  Direction of stepper motor driver
int Sleep =   4; // Control Sleep Mode on A4988
int MS1 =     7; // MS1 for A4988
int MS2 =     6; // MS2 for A4988
int MS3 =     5; // MS3 for A4988
int Step1 =   9; // Step of the second stepper motor driver
int Dire1 =  13; // Direction of the second stepper motor driver
int Sleep1 = 11; // Sleep mode for second stepper motor driver
int MS11 =   12; // MS1 for the second A4988
int MS21 =   10; // Merging MS21 and MS31 to allow full and half steps,
int MS31 =   10; // This has to be done because the number of pins avalible has reached capacity
enum movementState  { // defining the three states motor #1 can exist in
  STATIONARY,
  CLOCKWISE,
  COUNTCLOCKWISE
enum movementState1 { // defining the three states motor #2 can exist in
  STATIONARY1,
  CLOCKWISE1,
  COUNTCLOCKWISE1
int i;
// motor specs
const int spr =    200; // Steps per revolution of the first motor
const int spr1 =   200; // Steps per revolution of the second motor
int RPM =          100; // Motor Speed in revolutions per minute
int Microsteps =     2; // Stepsize (1 for full steps, 2 for half steps, 4 for quarter steps, etc)
const int maxRPM = 100; // gives limits on the fastest the motor can move. Changing this will change the maximum RPM
const int minRPM =   0; // gives limits for the slowest the motor can move. Changing this will chnage the minimum RPM
enum movementState   currentState; // This creates an enclosed function that can process the movement states of motor #1
enum movementState1 currentState1; // This creates an enclosed function that can process the movement states of motor #2
// A4988 pins
A4988 stepper  (spr, Dire, Step, MS1, MS2, MS3); // This defines the pins of the first stepper motor driver
A4988 stepper1(spr1,Dire1,Step1,MS11,MS21,MS31); // This defines the pins of the second stepper motor driver
  pinMode(SW_pin,    INPUT);
  digitalWrite(SW_pin,HIGH);
  pinMode(Step,     OUTPUT); // Step pin as output
  pinMode(Dire,     OUTPUT); // Direction pin as output for the first Stepper motor driver
  pinMode(Sleep,    OUTPUT); // Set Sleep OUTPUT Control button as output for the first Stepper motor driver
  digitalWrite(Step,   LOW); // Start with no stepper motor movement for the first Stepper motor driver
  digitalWrite(Dire,   LOW); // Start with no directional movement for the first Stepper motor driver
  pinMode(Step1,    OUTPUT); // Step1 pin as output for the second Stepper motor driver
  pinMode(Dire1,    OUTPUT); //Direction1 pin as output for the second Stepper motor driver
  pinMode(Sleep1,   OUTPUT); //Set Sleep1 OUTPUT Control button as output for the second Stepper motor driver
  digitalWrite(Step1,  LOW); // Start with no stepper motor movement on the second Stepper motor driver
  digitalWrite(Dire1,  LOW); // Start with no directional movement for the second Stepper motor driver
  currentState =       STATIONARY; // defining the start position for the first stepper motor
  currentState1 =     STATIONARY1; // defining the start position for the second stepper motor
  stepper.begin(RPM,  Microsteps);
  stepper1.begin(RPM, Microsteps);
  int xAxis = analogRead(X_pin); // defining the X-value given through the controller
  int yAxis = analogRead(Y_pin); // defining the Y-value given through the controller
  digitalWrite(Sleep, HIGH); // This takes the first motor out of sleep mode
  digitalWrite(Sleep1,HIGH); // This takes the second motor out of sleep mode
//  Serial.print("Y-axis:  ");
//  Serial.println(analogRead(Y_pin));
//  Serial.print("\n\n");
//  Serial.print("X-axis:  ");
//  Serial.println(analogRead(X_pin));
  int adjJoystick = calc(analogRead(Y_pin)); // adjJoystick is the adjusted value of the joystick to fit between +- 100, also used in setting RPM
  switch (currentState) {
    case STATIONARY:
      // Stationary Code - Hard stop, no motor movement, clear all movement actions
      stepper.stop(); // stops the movement when the controller is stationary
      Serial.print("STATIONARY: ");
      Serial.println(adjJoystick );
//    delay(450);
      if(adjJoystick > 2){ // The resting position of +-2 provides plenty of room for the motor to still function incase of controller drift.
        currentState = CLOCKWISE; // if the RPM found on the Serial Moniter rises above 2, then follow the code found in the clockwise case.
      } else if (adjJoystick < -2) {
        currentState = COUNTCLOCKWISE; // if the RPM found on the Serial Moniter falls below -2, then follow the code found in the countclockwise case.
    case CLOCKWISE:
      digitalWrite(Dire, HIGH); // sets the direction of motor 1 to Clockwise
      stepper.setRPM(adjJoystick);
      stepper.move(8);
      Serial.print("CLOCKWISE: ");
      Serial.println(adjJoystick);
//    delay(100);
      if(adjJoystick <= 2 && adjJoystick >= -2){
        currentState = STATIONARY; // if the RPM found on the Serial Moniter rises above -2 AND falls under 2, then follow the code found in the stationary case.
    case COUNTCLOCKWISE:
      digitalWrite(Dire, LOW); // sets the direction of motor 1 to CounterClockwise
      stepper.move(8);
      Serial.print("COUNTERCLOCKWISE: ");
//    delay(100);
      } else if (adjJoystick > 2){
    default:
//    Something has gone very very wrong if this is true.
      Serial.println("UHOH");
  int adjJoystick1 = calc(analogRead(X_pin));// adjJoystick1 is the adjusted value of the joystick to fit between +- 100, also used in setting RPM
  switch (currentState1) {
    case STATIONARY1:
      stepper1.stop();
      Serial.print("STATIONARY 1: ");
      Serial.println(adjJoystick1);
//    delay(450);
      if(adjJoystick1 > 2){
        currentState1 = CLOCKWISE1; // if the RPM found on the Serial Moniter rises above 2, then follow the code found in the clockwise1 case.
      } else if (adjJoystick1 < -2) {
        currentState1 = COUNTCLOCKWISE1; // if the RPM found on the Serial Moniter falls below -2, then follow the code found in the countclockwise1 case.
    case CLOCKWISE1:
      digitalWrite(Dire1, HIGH); // sets the direction of motor 2 to Clockwise
      stepper1.setRPM(adjJoystick1);
      stepper1.move(8);
      Serial.print("CLOCKWISE 1: ");
//    delay(100);
      if(adjJoystick1 <= 2 && adjJoystick1 >= -2){
        currentState1 = STATIONARY1; // if the RPM found on the Serial Moniter rises above -2 AND falls under 2, then follow the code found in the stationary1 case.
      digitalWrite(Dire1, LOW); // sets the direction of motor 2 to CounterClockwise
      stepper1.move(8);
      Serial.print("COUNTERCLOCKWISE 1: ");
//    delay(100);
      } else if (adjJoystick1 > 2){
    default:
int calc(int x ) { // this equation defines the term calc
  float k = x - 512;  // k is kvalue, it is the conversion from the controller range of 1024 down to the motor range of 100 RPM. x is xvalue, it's the incriment between 0-1024 displayed as between -512 -> 512
        k = k*0.195;  // ratio of controller range to RPM. 512 for the controller, and 100RPM for the motor
  return (int)k;
[/code]
What are they supposed to do?
NEMA17 identifies the size of the faceplate (1.7"). Verify your motors are unipolar, bipolar, RPM, input, et c., with their datasheet.
they send signals to the motor that control speed and direction. But I'm not sure why they aren't working. The problem isn't the wiring since the motors were able to swap directions when I uploaded some test code.
they are bipolar, and they are capable of changing direction
Do you have the enable pin hardwired to the correct value (5V or 0) depending on if it enable high or low? You can always add enable as a parameter when you instantiate the stepper.
Could you please post a wiring diagram (not Fritzing, but OK if hand drawn on a piece of paper) and some pictures of how you have your setup connected?
Here is what I found on the Github repo for A4988 library:
    // mover method:
    void setDirection(int direction);     // 0 forward, 1 backward
    void step(unsigned long num_steps);   // step a given number of steps
The method does not take negative numbers. To travel in the opposite direction, you need to use a positive number in step() and put 0 or 1 in setDirection().
