I want to let to stay on for 50 milliseconds, bit the time btw blinks to be 1000 miliseconds.
Doing it with delay is straightforward but we all know this kill everything else in the program.
How would i go around this to in order to get the time btw blinks?
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 100; //the value is a number of milliseconds
const byte ledPin = 13; //using the built in LED
Serial.begin(115200); //start Serial in case we need to print debugging info
pinMode(ledPin, OUTPUT);
startMillis = millis(); //initial start time
currentMillis = millis(); //get the current "time" (actually the number of milliseconds since the program started)
if (currentMillis - startMillis >= period) //test whether the period has elapsed
digitalWrite(ledPin, !digitalRead(ledPin)); //if so, change the state of the LED. Uses a neat trick to change the state
startMillis = currentMillis; //IMPORTANT to save the start time of the current LED state.
I've modified your code for 50ms ON, 1000ms OFF but hopefully it's not a prob for you to tweak it for the other timing it that's what you want!
const unsigned long OFFtime = 1000; //OFF time
const unsigned long ONtime = 50; //ON time
if (digitalRead(ledPin)==HIGH && currentMillis - startMillis >= ONtime) //test whether the ON period has elapsed
digitalWrite(ledPin, LOW); //if so, change the state of the LED to LOW.
else if (currentMillis - startMillis >= OFFtime) //test whether the OFF period has elapsed
digitalWrite(ledPin, HIGH); //if so, change the state of the LED to HIGH.
