Dual trigger off one input ?
Hello there,
Literally had a project dumped on my lap that require me to send 2 triggers off one input on a 'Makey Makey'.
I know very little about either Arduino or the hardware presented but I have to come up with a quick solution to the task in hand, which I'm sure the experienced members of this board will probably think childs play !! To me, its all alien.
Using the board, I need to be able, per input, to send a command to activate a certain piece of media on a PC. This is done by a letter + Enter, so for example W - Delay - Enter, to play that particular video file.
The playback software has no autoplay on each file so has to be activated unfortunately with an enter press.
So I assume in non code talk I need -
'Button Press' W
'Delay' 300
'Button Press' Enter
Help !
You obviously have some code you need to modify. So, post it.
What inputs do you have/expect? How does pressing W, waiting, then pressing Enter constitute two triggers?
Morning, sorry I'm a total novice at this (about half an hour !) so please excuse my ignorance.
Currently the code looks like this (irrelevant parts removed so that it is small enough for the forum)
#define BUFFER_LENGTH    3     // 3 bytes gives us 24 samples
#define NUM_INPUTS       18    // 6 on the front + 12 on the back
#define TARGET_LOOP_TIME 744  // (1/56 seconds) / 24 samples = 744 microseconds per sample
#define MOUSE_MOVE_UP       -1
#define MOUSE_MOVE_DOWN     -2
#define MOUSE_MOVE_LEFT     -3
#define MOUSE_MOVE_RIGHT    -4
#include <Keyboard.h>
#include <Mouse.h>
#include "settings.h"
STRUCT
typedef struct {
  byte pinNumber;
  int keyCode;
  byte measurementBuffer[BUFFER_LENGTH];
  boolean oldestMeasurement;
  byte bufferSum;
  boolean pressed;
  boolean prevPressed;
  boolean isMouseMotion;
  boolean isMouseButton;
  boolean isKey;
MakeyMakeyInput;
MakeyMakeyInput inputs[NUM_INPUTS];
VARIABLES
int bufferIndex = 0;
byte byteCounter = 0;
byte bitCounter = 0;
int mouseMovementCounter = 0; // for sending mouse movement events at a slower interval
int pressThreshold;
int releaseThreshold;
boolean inputChanged;
int mouseHoldCount[NUM_INPUTS]; // used to store mouse movement hold data
int pinNumbers[NUM_INPUTS] = {
  12, 8, 13, 15, 7, 6,     // top of makey makey board
  5, 4, 3, 2, 1, 0,        // left side of female header, KEBYBOARD
  23, 22, 21, 20, 19, 18   // right side of female header, MOUSE
const int inputLED_a = 9;
const int inputLED_b = 10;
const int inputLED_c = 11;
const int outputK = 14;
const int outputM = 16;
byte ledCycleCounter = 0;
int loopTime = 0;
int prevTime = 0;
int loopCounter = 0;
FUNCTIONS
void initializeArduino();
void initializeInputs();
void updateMeasurementBuffers();
void updateBufferSums();
void updateBufferIndex();
void updateInputStates();
void sendMouseButtonEvents();
void sendMouseMovementEvents();
void addDelay();
void cycleLEDs();
void danceLeds();
void updateOutLEDs();
SETUP
  initializeInputs();
  danceLeds();
MAIN LOOP
  updateBufferSums();
  cycleLEDs();
  updateOutLEDs();
  addDelay();
INITIALIZE ARDUINO
void initializeArduino() {
#ifdef DEBUG
  Serial.begin(9600);  // Serial for debugging
#endif
  for (int i=0; i<NUM_INPUTS; i++)
    pinMode(pinNumbers[i], INPUT);
    digitalWrite(pinNumbers[i], LOW);
  pinMode(inputLED_a, INPUT);
  pinMode(inputLED_b, INPUT);
  pinMode(inputLED_c, INPUT);
  digitalWrite(inputLED_a, LOW);
  digitalWrite(inputLED_b, LOW);
  digitalWrite(inputLED_c, LOW);
  pinMode(outputK, OUTPUT);
  pinMode(outputM, OUTPUT);
  digitalWrite(outputK, LOW);
  digitalWrite(outputM, LOW);
#ifdef DEBUG
  delay(4000); // allow us time to reprogram in case things are freaking out
#endif
  Keyboard.begin();
  Mouse.begin();
INITIALIZE INPUTS
void initializeInputs() {
  float thresholdPerc = SWITCH_THRESHOLD_OFFSET_PERC;
  float thresholdCenterBias = SWITCH_THRESHOLD_CENTER_BIAS/50.0;
  float pressThresholdAmount = (BUFFER_LENGTH * 8) * (thresholdPerc / 100.0);
  float thresholdCenter = ( (BUFFER_LENGTH * 8) / 2.0 ) * (thresholdCenterBias);
  pressThreshold = int(thresholdCenter + pressThresholdAmount);
  releaseThreshold = int(thresholdCenter - pressThresholdAmount);
#ifdef DEBUG
  Serial.println(pressThreshold);
  Serial.println(releaseThreshold);
#endif
  for (int i=0; i<NUM_INPUTS; i++) {
    inputs[i].pinNumber = pinNumbers[i];
    inputs[i].keyCode = keyCodes[i];
    for (int j=0; j<BUFFER_LENGTH; j++) {
      inputs[i].measurementBuffer[j] = 0;
    inputs[i].oldestMeasurement = 0;
    inputs[i].bufferSum = 0;
    inputs[i].pressed = false;
    inputs[i].prevPressed = false;
    inputs[i].isMouseMotion = false;
    inputs[i].isMouseButton = false;
    inputs[i].isKey = false;
    if (inputs[i].keyCode < 0) {
#ifdef DEBUG_MOUSE
      Serial.println("GOT IT");
#endif
      inputs[i].isMouseMotion = true;
    else if ((inputs[i].keyCode == MOUSE_LEFT) || (inputs[i].keyCode == MOUSE_RIGHT)) {
      inputs[i].isMouseButton = true;
    else {
      inputs[i].isKey = true;
#ifdef DEBUG
    Serial.println(i);
#endif
UPDATE MEASUREMENT BUFFERS
void updateMeasurementBuffers() {
       byte currentByte = inputs[i].measurementBuffer[byteCounter];
    inputs[i].oldestMeasurement = (currentByte >> bitCounter) & 0x01;
   boolean newMeasurement = digitalRead(inputs[i].pinNumber);
   newMeasurement = !newMeasurement;
    if (newMeasurement) {
      currentByte |= (1<<bitCounter);
    else {
      currentByte &= ~(1<<bitCounter);
    inputs[i].measurementBuffer[byteCounter] = currentByte;
UPDATE BUFFER SUMS
void updateBufferSums() {
    boolean currentMeasurement = (currentByte >> bitCounter) & 0x01;
    if (currentMeasurement) {
      inputs[i].bufferSum++;
    if (inputs[i].oldestMeasurement) {
      inputs[i].bufferSum--;
UPDATE BUFFER INDEX
void updateBufferIndex() {
  bitCounter++;
  if (bitCounter == 8) {
    bitCounter = 0;
    byteCounter++;
    if (byteCounter == BUFFER_LENGTH) {
      byteCounter = 0;
UPDATE INPUT STATES
void updateInputStates() {
  inputChanged = false;
    inputs[i].prevPressed = inputs[i].pressed; // store previous pressed state (only used for mouse buttons)
    if (inputs[i].pressed) {
      if (inputs[i].bufferSum < releaseThreshold) {
        inputChanged = true;
        if (inputs[i].isKey) {
          Keyboard.release(inputs[i].keyCode);
        if (inputs[i].isMouseMotion) {
          mouseHoldCount[i] = 0;  // input becomes released, reset mouse hold
      else if (inputs[i].isMouseMotion) {
        mouseHoldCount[i]++; // input remains pressed, increment mouse hold
    else if (!inputs[i].pressed) {
      if (inputs[i].bufferSum > pressThreshold) {  // input becomes pressed
        inputs[i].pressed = true;
          Keyboard.press(inputs[i].keyCode);
#ifdef DEBUG3
  if (inputChanged) {
    Serial.println("change");
#endif
ADD DELAY
void addDelay() {
  loopTime = micros() - prevTime;
  if (loopTime < TARGET_LOOP_TIME) {
    int wait = TARGET_LOOP_TIME - loopTime;
    delayMicroseconds(wait);
  prevTime = micros();
#ifdef DEBUG_TIMING
  if (loopCounter == 0) {
    int t = micros()-prevTime;
    Serial.println(t);
  loopCounter++;
  loopCounter %= 999;
#endif
  if (keyPressed)
    digitalWrite(outputK, HIGH);
    TXLED1;
    TXLED0;
  if (mousePressed)
    digitalWrite(outputM, HIGH);
    RXLED1;
    RXLED0;
Key assignment is done as such -
int keyCodes[NUM_INPUTS] = {
  'w',                // pin D5
  'a',                // pin D4
  's',                // pin D3
  'd',                // pin D2
  'f',                // pin D1
  'g',                // pin D0
For arguments sake, what I'd like to achieve is a trigger of pin D5 for example could select the video file associated with 'W' and then trigger an ENTER command, if that makes sense ?
Which Arduino are you using?
Well, that's so easy. All you need to do is
Good luck.
