Hola a todos, tengo un robot bipedo con 6 servos que salen desde un arduino uno y ahora quiero intercalar un servo shield de 16 servos para montarle los brazos y cabeza. El problema es que no se como se identifican los servos para poder enviarle los movimientos independientes. Me he descargo este ejemplo de adafruit pero no consigo entender como seleccionar un servo concreto.
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN 150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // this is the 'maximum' pulse length count (out of 4096)// our servo # counter
uint8_t servonum = 0;void setup() {
Serial.println("16 channel Servo test!");pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
}// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;pulselength = 1000000; // 1,000,000 us per second
pulselength /= 60; // 60 Hz
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000;
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
}void loop() {
// Drive each servo one at a time
Serial.println(servonum);
for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
pwm.setPWM(servonum, 0, pulselen);
for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
delay(500);servonum ++;
if (servonum > 15) servonum = 0;
