Due & A4988 stepper motor issue on one axis (RADDS v1.5)
Thanks very much for your reply.
Yes, that's what I meant. If I replace those Z pin numbers with the X pin numbers, the X stepper runs, but when I replace them with the Y pin numbers, the Y stepper doesn't run.
I wish I could say that pulling the enable pin LOW worked, but it unfortunately didn't make a difference :frowning:
Since the drivers are wired into the RADDS board, which stacks on the Due, yes, the RADDS board's circuitry determines which Due pins correspond to various driver pins. I'm rock-solid certain that these pins are correct and not swapped around; I contacted the manufacturer to make sure.
In all honesty, I am quite stumped. Perhaps the board is defective--maybe Repetier does something that shouldn't be necessary if the hardware is fully functional, but provides a fix if there's a break or problem somewhere (in my case, in the Y-axis).
