This software combines with an Arduino DUE with CAN BUS Transceiver to manage a TC 3.3 KW charger for my electric vehicle.
The charger expects to receive a CAN message every second from my BMS with a CAN message ID of 0x1806E5F4 and eight data bits detailing voltage and amperage required. When I send this extended ID message from the DUE it appears on the CAN bus but appears with a standard message ID - that the charger ignores.
I have confirmed that the charger operates correctly when I send the extended CAN bus message using a Microchip CAN bus analyzer using its transmit function.
It would seem to me to be a coding problem so here is my code:
#include "variant.h"
#include <due_can.h>
#include <stdio.h>
word outputvoltage = 0x0646; //0x05A0 is max voltage of 160.6V (offset = 0.1)
word outputcurrent = 0x0078; //0x0078 set max current to 12 amps (abs max 23A, offset = 0.1)
word volts = 0;
word amps = 0;
boolean chargerStatus = 0; //0 is charging
unsigned long int DatafromChargerId = 0x18FF50E5;
unsigned long int BMStoChargerId = 0x1806E5F4;
CAN_FRAME ChargerCanFrame; // BMS sending
CAN_FRAME ChargerStatusCanFrame; // BMS receiving
pinMode(62, OUTPUT);
ChargerCanFrame.extended;
ChargerStatusCanFrame.extended;
while (!Can0.begin(250000, 62)) {
Serial.println("CAN0 initialization (sync) ERROR\n");
delay(100);
Serial.println("Using Can0 - initialisation completed");
ChargerCanFrame.id = BMStoChargerId; //0x1806E5F4;
ChargerCanFrame.length = 8;
ChargerCanFrame.data.bytes[0] = highByte(outputvoltage);
ChargerCanFrame.data.bytes[1] = lowByte(outputvoltage);
ChargerCanFrame.data.bytes[2] = highByte(outputcurrent);
ChargerCanFrame.data.bytes[3] = lowByte(outputcurrent);
ChargerCanFrame.data.bytes[4] = 0x00; //0 means ok to charge
ChargerCanFrame.data.bytes[5] = 0x00;
ChargerCanFrame.data.bytes[6] = 0x00;
ChargerCanFrame.data.bytes[7] = 0x00;
Can0.setRXFilter(1, 0x18FF50E5, 0x7FFFFFFF, true);
Can0.attachCANInterrupt(1, extractData);
Can0.sendFrame(ChargerCanFrame);
void extractData(CAN_FRAME *frame) {
volts = word(frame->data.bytes[0], frame->data.bytes[1]); // frame->data.bytes[0] is highByte. RPM works for display on 4d Systems screen - same scaling 1
amps = word(frame->data.bytes[2], frame->data.bytes[3]);
chargerStatus = frame->data.bytes[4];
Any help gratefully received.
