DUE and wire library (IDE 1.8.2 and last libraries as 16/07/2017)
Hello,
When compiling a sample (master_reader.ino) or a more complex sketch with my DUE, the compiler is complaining :
In file included from C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.cpp:25:0:
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.h: In constructor ‘TwoWire::TwoWire(Twi*, void ()(), void ()())’:
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.h:96:7: warning: ‘TwoWire::twi’ will be initialized after [-Wreorder]
Twi *twi;
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.h:72:10: warning: ‘uint8_t TwoWire::rxBufferIndex’ [-Wreorder]
uint8_t rxBufferIndex;
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.cpp:95:1: warning: when initialized here [-Wreorder]
TwoWire::TwoWire(Twi _twi, void(_beginCb)(void), void(*_endCb)(void)) :
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.h:108:16: warning: ‘TwoWire::status’ will be initialized after [-Wreorder]
TwoWireStatus status;
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.h:90:30: warning: ‘void (* TwoWire::onBeginCallback)()’ [-Wreorder]
void (*onBeginCallback)(void);
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.cpp: At global scope:
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.cpp:145:9: warning: unused parameter ‘sendStop’ [-Wunused-parameter]
uint8_t TwoWire::requestFrom(uint8_t address, uint8_t quantity, uint32_t iaddress, uint8_t isize, uint8_t sendStop) {
C:\Users\Pierre\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src\Wire.cpp:212:9: warning: unused parameter ‘sendStop’ [-Wunused-parameter]
uint8_t TwoWire::endTransmission(uint8_t sendStop) {
I don’t understand why and how could i remove these warnings.
Pierre
