Hi all l have goggled without luck re my error, using IDE 1.8.16, l get the above title error when trying to compile the wire digital_potentiometer example, for the Arduino Due(native port).
Any help appreciate (but please keep it at a coding dummy level)
Arduino: 1.8.16 (Windows 10), TD: 1.55, Board: "Arduino Due (Native USB Port)"
C:\Users\61437\Documents\arduino-1.8.16\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\61437\Documents\arduino-1.8.16\hardware -hardware C:\Users\61437\AppData\Local\Arduino15\packages -tools C:\Users\61437\Documents\arduino-1.8.16\tools-builder -tools C:\Users\61437\Documents\arduino-1.8.16\hardware\tools\avr -tools C:\Users\61437\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\61437\Documents\arduino-1.8.16\libraries -libraries C:\Users\61437\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x -vid-pid=1A86_7523 -ide-version=10816 -build-path C:\Users\61437\AppData\Local\Temp\arduino_build_607657 -warnings=none -build-cache C:\Users\61437\AppData\Local\Temp\arduino_cache_172018 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\examples\digital_potentiometer\digital_potentiometer.ino
C:\Users\61437\Documents\arduino-1.8.16\arduino-builder -compile -logger=machine -hardware C:\Users\61437\Documents\arduino-1.8.16\hardware -hardware C:\Users\61437\AppData\Local\Arduino15\packages -tools C:\Users\61437\Documents\arduino-1.8.16\tools-builder -tools C:\Users\61437\Documents\arduino-1.8.16\hardware\tools\avr -tools C:\Users\61437\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\61437\Documents\arduino-1.8.16\libraries -libraries C:\Users\61437\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x -vid-pid=1A86_7523 -ide-version=10816 -build-path C:\Users\61437\AppData\Local\Temp\arduino_build_607657 -warnings=none -build-cache C:\Users\61437\AppData\Local\Temp\arduino_cache_172018 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\61437\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\examples\digital_potentiometer\digital_potentiometer.ino
Using board 'arduino_due_x' from platform in folder: C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
Using core 'arduino' from platform in folder: C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
Detecting libraries used...
"C:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10816 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\sketch\\digital_potentiometer.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10816 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src" "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\sketch\\digital_potentiometer.ino.cpp" -o nul
"C:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10816 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src" "C:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src\\Wire.cpp" -o nul
Generating function prototypes...
"C:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10816 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src" "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\sketch\\digital_potentiometer.ino.cpp" -o "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\61437\\Documents\\arduino-1.8.16\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10816 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "-IC:\\Users\\61437\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\libraries\\Wire\\src" "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\sketch\\digital_potentiometer.ino.cpp" -o "C:\\Users\\61437\\AppData\\Local\\Temp\\arduino_build_607657\\sketch\\digital_potentiometer.ino.cpp.o"
In file included from C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\examples\digital_potentiometer\digital_potentiometer.ino:15:0:
C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\src/Wire.h:120:16: error: cannot declare variable 'Wire' to be of abstract type 'TwoWire'
extern TwoWire Wire;
C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\src/Wire.h:35:7: note: because the following virtual functions are pure within 'TwoWire':
class TwoWire : public Stream {
In file included from C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/Stream.h:26:0,
from C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/HardwareSerial.h:25,
from C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/Arduino.h:195,
from C:\Users\61437\AppData\Local\Temp\arduino_build_607657\sketch\digital_potentiometer.ino.cpp:1:
C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino/Print.h:50:17: note: virtual int Print::availableForWrite()
virtual int availableForWrite(void) = 0;
C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\src/Wire.h:123:16: error: cannot declare variable 'Wire1' to be of abstract type 'TwoWire'
extern TwoWire Wire1;
C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire\src/Wire.h:35:7: note: since type 'TwoWire' has pure virtual functions
Using library Wire at version 1.0 in folder: C:\Users\61437\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\libraries\Wire
exit status 1
Error compiling for board Arduino Due (Native USB Port).
