Hey Guys,
First time poster... I've been writing a WebServer (with SDFat.h) with Mega and needed to port it to DUE. When I ran the same program on a DUE it didn't work, as in the Device went as far as pinging and finding the file on the SD card but no further. Assuming its my code (which ran perfectly on Mega) I loaded the WebServer sample sketch to the DUE.
It did work fine, so to diagnose then I added SD.begin after the server to check the SD card, sure enough, found the SD card but it showed
server is at 255.255.255.255
After reading few posts I switched the setup order of Ethernet and SD (to check), then I got,
server is at 0.0.0.0.
Then went on to read few more posts and did some checking with driving pins 4,10, 53 high and low. But whatever the situation once the SD is initialized, I cannot get the Ethernet to work, its like its forced on the SPI bus.
Lastly I tried the official SD.h and it worked, the reason I want SDfat is its support for long file names.
My testing code,
#include <SPI.h>
#include <Ethernet.h>
//#include <SD.h>
#include <SdFat.h>
SdFat SD;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0E, 0xCA, 0x2F }; //Copied from internet
byte subnet[] = { 255, 255, 255, 0 };
byte gateway[] = { 192, 168, 8, 1 };
IPAddress ip(192, 168, 8, 123);
// Initialize the Ethernet server library (port 80 is default for HTTP)
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
pinMode(10, OUTPUT);
digitalWrite(10, LOW);
pinMode(53, OUTPUT);
digitalWrite(53, HIGH);
Ethernet.begin(mac, ip, subnet, gateway);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
pinMode(4, OUTPUT);
digitalWrite(10, HIGH);
if (!SD.begin(4)) {
Serial.println("initialization failed!");
}else{
Serial.println("initialization done.");
if (SD.exists("index.htm")) {
Serial.println("Found a /index.htm file!");
pinMode(4, OUTPUT);
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
This issue has been observed earlier
https://forum.arduino.cc/index.php?topic=146187.0
But SDFatConfig.h has changed since, though I changed below values to "1"
#define ENABLE_EXTENDED_TRANSFER_CLASS 0
#define USE_STANDARD_SPI_LIBRARY 0
I wasn't successful, If any one can, please let me know what could be happening and possibly how to get it sorted.
Thanks in advance.
