Due Flash Memory
Hello,
I have a collection of short music samples and effects for a board game. The sounds don't change and would ideally be included with a sketch at compile time.
I would like to burn then into the DUE from the IDE and then read the audio data from FLASH whilst the program is running.
Is this possible?
Thanks
Pascal
PascalMcFortran:
Hello,
Is this possible?
Thanks
Pascal
You need to do it like this:
const byte sound[something] =
Data here
Do you mean like including a binary file into a sketch? I've done it on Linux using inline assembler, I don't know if the same trick will work on Windows or Mac though.
extern char binfile[];
 asm(   "\n.section .text\n.globl binfile \n binfile : \n.incbin \"/home/user/full/path/to/sketch/file.bin\" \n");
  char tmp[1000];
  for(int i=0;i<999;i++)tmp[i]=*(binfile+i);
  tmp[999]=0;
  Serial.println(tmp);
  Serial.println((long)binfile,HEX);
