Due I2C Nack Attack
I tried using the following example sketch to interface with my LidarLite V3 distance sensor on my Due, but all I get in the serial monitor are nacks! On the flip side, the example works perfectly with my Mega.
Circuit stuff: I'm using a TXS0108E level shifter, 2.2K pullups on the 5V I2C lines, 100uF cap on the 5V supply, and a buck converter for the 5V power supply (all grounds connected).
Can anyone else get this code to work with the Due?
  LIDARLite Arduino Library
  GetDistanceI2c
  This example shows how to initialize, configure, and read distance from a
  LIDAR-Lite connected over the I2C interface.
  Connections:
  LIDAR-Lite 5 Vdc (red) to Arduino 5v
  LIDAR-Lite I2C SCL (green) to Arduino SCL
  LIDAR-Lite I2C SDA (blue) to Arduino SDA
  LIDAR-Lite Ground (black) to Arduino GND
  (Capacitor recommended to mitigate inrush current when device is enabled)
  680uF capacitor (+) to Arduino 5v
  680uF capacitor (-) to Arduino GND
  See the Operation Manual for wiring diagrams and more information:
  http://static.garmin.com/pumac/LIDAR_Lite_v3_Operation_Manual_and_Technical_Specifications.pdf
#include <Wire.h>
#include <LIDARLite.h>
LIDARLite myLidarLite;
  Serial.begin(115200); // Initialize serial connection to display distance readings
    begin(int configuration, bool fasti2c, char lidarliteAddress)
    Starts the sensor and I2C.
    Parameters
    configuration: Default 0. Selects one of several preset configurations.
    fasti2c: Default 100 kHz. I2C base frequency.
      If true I2C frequency is set to 400kHz.
    lidarliteAddress: Default 0x62. Fill in new address here if changed. See
      operating manual for instructions.
  myLidarLite.begin(0, true); // Set configuration to default and I2C to 400 kHz
    configure(int configuration, char lidarliteAddress)
    Parameters
      0: Default mode, balanced performance.
      1: Short range, high speed. Uses 0x1d maximum acquisition count.
      2: Default range, higher speed short range. Turns on quick termination
          detection for faster measurements at short range (with decreased
          accuracy)
      3: Maximum range. Uses 0xff maximum acquisition count.
      4: High sensitivity detection. Overrides default valid measurement detection
          algorithm, and uses a threshold value for high sensitivity and noise.
      5: Low sensitivity detection. Overrides default valid measurement detection
          algorithm, and uses a threshold value for low sensitivity and noise.
  myLidarLite.configure(0); // Change this number to try out alternate configurations
    distance(bool biasCorrection, char lidarliteAddress)
    Take a distance measurement and read the result.
    Parameters
    biasCorrection: Default true. Take aquisition with receiver bias
      correction. If set to false measurements will be faster. Receiver bias
      correction must be performed periodically. (e.g. 1 out of every 100
      readings).
  // Take a measurement with receiver bias correction and print to serial terminal
  Serial.println(myLidarLite.distance());
  // Take 99 measurements without receiver bias correction and print to serial terminal
  for(int i = 0; i < 99; i++)
    Serial.println(myLidarLite.distance(false));
SCL0 / SDA0 did have pullups builtin but not SCL1 / SDA1.
On SCL1/ SDA1 you need Pullups about 2k2 Ohm on both (connected to 3.3 V) and replace everywhere wire by wire1.
If you have a long I2C bus, you have ringing on the falling edges, and the clocks coming into your board will have glitches on the order of 50ns. See this thread reply #19 for a workaround:
https://forum.arduino.cc/index.php?topic=358428.15
I was just wondering if you were you able to get the Lidar Lite to work with your Arduino Due using I2C? I am having the same issues trying to get mine to work. I was successful with it on the Arduino Uno, just not the Due.
