Actually, it's my code which was bad, I modified it and all worked fine for me
Sorry for disturbing.
Patouf:
Actually, it's my code which was bad, I modified it and all worked fine for meSorry for disturbing.
It would be nice if you share your new code with us.
yep sorry. here it goes: for the Due (master)
#include <Wire.h>
int old, now;
Wire.begin();
Serial.println("I2C test starting...");
old=millis();now=millis();
if(Serial.available())
Wire.beginTransmission(0x02);
Wire.write(Serial.read());
Wire.endTransmission();
old=now;
Wire.requestFrom(0x02,1);
//delay(1);
while(Wire.available())
char c=Wire.read();
if(c>31)Serial.println(c);
and for the Uno:
#include <Wire.h>
char buffer[256];
byte serialpos=0, wirepos=0;
Wire.begin(0x02);
Serial.println("I2C test Starting...");
Wire.onRequest(handler);
Wire.onReceive(receiver);
void loop() { // put your main code here, to run repeatedly:
void handler()
char c=Serial.read();
Wire.write(c);
void receiver(int num)
char c=Wire.read();
Serial.println(c);
Hope this helps ![]()
Finally some good news that you've got I2C working..
I recently got my Due about a day back and tried using I2C, by sending a byte over to my target external ADC (that communicates using I2C). The device address is 0x0D, target register address is 0x80 and the byte to be sent is 0xA0.
#include <Wire.h>
byte result=0;
Wire.begin(0x0D); //device address
delay(10);
//main code here, to run over and over again
Wire.beginTransmission(0x80); //target register address
delay(1);
Wire.write(0xA0); //data byte to be transmitted
delay(1);
result=Wire.endTransmission(); //wanted to print the status of transmission as i cannot program my
delay(1); target IC (external ADC)
Serial.write(result);
Serial.println(" ");
delay(100);
Im getting the following message on my serial monitor:
assertion "(address & 0x80) == 0" failed: file "../source/twi.c", line 261, function: TWI_StartWrite
Exiting with status 1.
I will be really grateful to anyone who can analyze Patouf's code in the previous post and point out the error (if any) in mine.
Thanks a lot guys.
Hello, guys.
I am experiencing the same issues with the TWI interface with Arduino DUE. I am trying to read data from a MMA8452Q accelerometer. It's a 3.3V powered sensor. The strange things are the following:
- Using the sensor with Arduino UNO with two 330 ohm resistor on the TWI wires (as suggested by the code example provided on GitHub) works perfectly, the sensor is readable.
- Connecting the same way Arduino UNO and Arduino DUE and scanning the TWI devices works for the Arduino UNO, it finds the DUE board, but the DUE board can't find the UNO board.
- The accelerometer with the DUE board does not work at all
It seems to be a software problem for the Wire library on Arduino DUE isn't it?
WIfAU
Did you ever figure out how to get the Due i2c to work?
No, I haven't. I think I'll use a oscilloscope to understand what is the issue and then I'll try to fix it.
Update: I got the my I2C devices working with the Due on both channels. 2.2K pullups on SDA1/SCL1. Haven't fully tested yet, but Due finds the device addresses. Used Newhobby's Wire library: Is I2C working correctly on 1.5.5?? - #26 by system - Arduino Due - Arduino Forum
I had the same problem with the GY-521.
Use the fix also worked for me.
Specifically:
Download:
And overwrite in your arduino installation: hardware/arduino/sam/libraries/Wire/Wire.cpp
For me, this just fixed i2c.
chriskner:
Do not connect two Due's together on a common I2C bus without a buffer of some sort. The combination of both boards, and their pull-up resistors in parallel, will unnecessarily stress the DUE's TWI pins. I recommend that the on-board pull-ups be removed from the DUE's pcb by default. Use larger external pull-up resistors.How big? Check this out:
http://www.edn.com/design/analog/4371297/Design-calculations-for-robust-I2C-communications
Hi Chris,
Great link! Someone pointed me to this post recently in concern about the 1.5K pullups I'd used in a Due-compatible design (the Freetronics EtherDue). The 1.5K values I'd used were the same as the Due reference design. I calculate that under normal circumstances (including connecting two Dues together over i2c) the onboard pullup selection is fine, no need to remove them.
According to the SAM3X8E datasheet Table 46-2, the TWI pins on the Due (ports PB12,13 & PA17,18) can individually sink 6mA for VOL = 0.4V, or sink 9mA in "Relaxed" mode for VOL=0.6V.
Pulling 3.3V down to 0.4V through a 1.5K resistor means sinking 1.93mA. So you can connect three Dues to the same i2c bus, if you needed to, for a combined super low 500 ohm pullup resistance, before you risk the low level voltage floating above 0.4V.
If you're feeling adventurous you could add a fourth and probably a fifth Due to a common i2c bus and push the low voltage up to 0.6V ("relaxed mode") before you risk damaging anything by sinking more than 9mA (the Dues will still be able to talk to each other, as their VIL is maximum 1V.)
It is definitely worth checking any other i2c device's specifications though, to make sure they can sink at least 2mA at 0.4V. This should be well within the limit for most devices, though. Mixing more than one Due on a single i2c bus with multiple other devices also on the bus is perhaps potentially risky, as by this point you have relatively high currents (4mA, 6mA) which may exceed some device limits. The only way to be sure would be to check each device's datasheet.
Why are the comparatively low resistance values on the Due design useful, when most i2c pullups are 4.7k or 10k? The reason is probably to deal with situations of high bus capacitance, especially when using fast mode (400kHz.) This is discussed in the excellent PDF you linked above. At 400kHz it's probably not as essential as it would be if the Due supported 1Mbit or 3.4Mbit "Faster" TWI, but it's still helpful to have the bus return to a "high" value as quickly as possible.
TLDR: Unless I missed something (and please tell me if I did), I wouldn't worry about removing the Due's standard pullups under normal conditions.
Hi again Chris,
I just saw your post on the other i2c thread about genuine Dues having 1K pullups, not 1.5K as shown on the schematic. I can confirm this on the genuine Due board I have here, as well.
In that case you're right that things are a bit more borderline, all calculations shown above get 50% worse. ie you can still connect most common i2c slave devices (specced as 0.4V / 3mA) without exceeding the specs, and two or three Dues can be joined together but probably no more. Mixing multiple Dues and other i2c devices all on the same bus is definitely a bad idea without removing some resistors.
I wonder why Arduino specced 1.5K pullups and then went with 1K in the factory!
- Angus
projectgus ,
All True... Except for if you produce a design based to operate just under the maximum allowed specifications, then you are making a product that has inherently reduced reliability and longevity (for no good reason). Stay well away from the max specs for catastrophic electrical failure, and you'll be much, much happier.
Presumably, the DUE was designed for experimenter's and novices, using 'typical' (common) interfaces. While pushing the speed boundaries of the I2C bus is a possibility, anyone serious about it would most likely use an I2C buffer with rise/fall time acceleration (and not rely on a uC's raw dio pin for drive capability). Considering the intended audience, the DUE design should error on the safer-side of electrical failure.
I truly believe that the pull-up resistor choice on the DUE was a mistake, and it would have been done differently if they had the chance to do it all over again. These things do happen.
Also, remember, the installed pull-up resistors are 1000 ohms, not 1500 (as shown in the prints). Two DUE's connected together puts the I2C dio pins right near max spec.
Regards,
Chris
Hi Chris,
I agree with you that the 1K thing is definitely a mistake, compared to 1.5K as per the reference design.
chriskner:
I agree also, but the limits we're talking about here aren't the limits for electrical failure. They're just the limits for normal operation with VOL<=0.4V (6mA). Exceed that limit and there's the next limit for VOL<=0.6V (9mA), also specified by the manufacturer as safe ("Relaxed mode"). Go past that and you've exceeded the safe specifications. The datasheet doesn't specify what the absolute limit is but you know for sure you can at least get to 9mA without compromising. Although I agree you want to design in headroom under normal operation.
This configuration puts the Due near the 6mA limit where the low voltage level may rise to 0.6V. No risk to the devices unless more than 50% more current draw appears from somewhere, to push past the "Relaxed Mode" specification of 9mA.
Of course if you connect some other i2c device to the same bus on top then it might not work, due to the low voltages possibly now being higher than 0.4V.
- Angus
This is a confirmed bug in the arduino Wire library: Fix for Due Wire library by bluesign2k · Pull Request #1994 · arduino/Arduino · GitHub
Specifically:
Download:
For me, this just fixed i2c on the Due.
Other people said that it gave a compile error - I don't know why.
I tried the wire.cpp fix on my Due using the Adafruit motor sheild v2 - and just one motor and it fails as soon as the motor starts spinning - which makes me think something in the hardware is failing using the i2c protocol as these shields operate with i2c in version #2.
This is my code below. If works with the MEGA but the due gives you the
assertion "(address & 0x80) == 0" failed: file "../source/twi.c", line 279, function: TWI_StartWrite
error.
I have tried to shift the the high bit to the right but that did not work. Any suggestions.
This this code has worked for a couple of years not problem
#include <Wire.h>
int temp_address = (0xFF); // Addres of Raytek Sensor//RAYTEK SETUP
unsigned int tek_temp;
unsigned char high, low, bytecount = 0;
Wire.begin();
Wire.beginTransmission(temp_address); //Begins transmission to Raytek sensor
Wire.write(7); // Write to address 0x07 Target/Ambient temperature register
Wire.endTransmission(false);//Ends transmisson to sensor but with False take staement allows sensor to still send back bytes
Wire.requestFrom(temp_address, 2); //Allows only first two bytes to be read from Raytek sensor
while (Wire.available())
if (bytecount == 0)// This buys some time
low = Wire.read();
bytecount++;
if (bytecount == 1)// This buys some time
high = Wire.read();
bytecount = 0;
tek_temp = (high * 256 + low) / 10; //Converts LSB AND MSB TO ACTUAL INT NUMBER
Serial.println(tek_temp);
// raytek_time = millis() + 200;
//genie.WriteObject(GENIE_OBJ_CUSTOM_DIGITS, 0x0B, tek_temp );
