I have a Arduino Due already setup and working with my Nextion LCD display and now i have been trying to add controls to my VFD via the rs485 board.
I followed the instructions from this site since it is the same VFD i have. Looking at the code it uses the sofwareserial.h
and from what I can gather it will not work with the DUE so I have purchased a mega2560 and it tests out fine via softwareserial only.
I want to use this on the actual hardware serial ports but so far on both the mega and due i cant get it to work on any of the serial ports onboard, is there something i am missing?
I have moved the Nextion LCD between serial ports and it works fine so i know the ports/boards are good it is just the rs485 board only seems to only work via the softwareserial.
I also have swapped around the RX/TX connections with no luck.
here is the original working VFD/rs485 code using the software serial which works fine on my mega board :
#include <SoftwareSerial.h>
// RS485 connections
// D8 = DI (TX)
// D9 = DE
// D10 = RE
// D11 = RO (RX)
// adjust speed
String speed=":010203030BB837\r\n";
char* read_speed=":01040300";
char* change_speed=":010203030BB8";
char* stop=":01030108";
char* start=":01030101";
SoftwareSerial myserial(11,8); // RX, TX
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
myserial.begin(9600);
digitalWrite(9,LOW); digitalWrite(9,LOW);
void setSpeed(int v) {
Serial.print("Set new speed "); Serial.println(v,DEC);
char* n=change_speed;
//char n[13];
//strcpy(n,change_speed);
n[9]=toHexa((v/256)>>4);
n[10]=toHexa((v/256)&0xf);
n[11]=toHexa((v&0xff)>>4);
n[12]=toHexa((v&0xff)&0xf);
Serial.println(n);
query(n); // set new speed
// while(myserial.available()) Serial.write(myserial.read());
query(start);
delay(10000);
//delay(5000);
for(long v=1000; v<16000; v+=1000) {setSpeed(v); delay(5000); }
query(stop);
delay(10000);
void transmit(String msg) {
// activate driver
digitalWrite(9,HIGH); digitalWrite(9,HIGH);
delay(50);
myserial.print(msg);
delay(1);
char hexa(char byte) { // return hexa value of that ASCII char
if(byte<='9') return byte & 0x0f;
if(byte<='F') return (byte & 0x0f) + 9; // A=0x41 --> 0x0a
char toHexa(int i) {
if(i<10) return 0x30 | i;
return 0x41 + i - 10;
char crc(char* buffer) {
int l=strlen(buffer);
int i=1;
int chk=0;
while(i<l) { Serial.print(hexa(buffer[i])<<4|hexa(buffer[i+1]),HEX); chk+= ( hexa(buffer[i])<<4|hexa(buffer[i+1]) ); i+=2; Serial.print(" ");}
Serial.print(":"); Serial.println(chk,HEX);
Serial.println(0x100-chk,HEX);
return (0x100-chk) & 0xff;
void query(char* cmd) {
char lrc = crc(cmd);
String msg = cmd;
msg+=toHexa((lrc&0xf0)>>4);
msg+=toHexa(lrc&0x0f);
msg+="\r\n";
Serial.print(msg);
transmit(msg);
here is the modified code to try and make it work with Serial2 on the onboard serial with the mega and due boards:
//#include <SoftwareSerial.h>
// D8 = DI (TX)
// D9 = DE
// D10 = RE
// D11 = RO (RX)
// adjust speed
//SoftwareSerial myserial(11,8); // RX, TX
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
//myserial.begin(9600);
Serial2.begin(9600);
//char n[13];
Serial.println(n);
query(start);
delay(10000);
//delay(5000);
query(stop);
delay(10000);
// activate driver
delay(50);
//myserial.print(msg);
Serial2.print(msg);
delay(1);
int i=1;
int chk=0;
String msg = cmd;
msg+="\r\n";
Serial.print(msg);
transmit(msg);
appreciate any help you can give…
thanks
James
