DUE: Reading Serial data into two dimensional array, it skips every other index.
As the title says I have a two dimensional array that I am attempting to read data into.
byte serialData[6][6]
If you look at the code below the idea is that I'm trying to take this
123456B789012C345678D012345E555555F666666
data and parse it. What I am doing appears to work great,
I use the SPACE char at the beginning to start the parse and then the B-F char to split the 6 bytes of data. Each time I get a new alpha char I am incrementing the first index of the array and then taking the data chars into the 2nd index.
When I print the values of serialData[i] I get the below results
[0]   = 111111
[0][1][2][3][4][5]
[1] = NULL
[0][1][2][3][4][5]
[2] = 222222
[0][1][2][3][4][5]
[3] = NULL
[0][1][2][3][4][5]
[4] = 333333
[0][1][2][3][4][5]
[5] = NULL
[0][1][2][3][4][5]
If I print even farther than I am even defining in the array...
serialData[6] = 444444
serialData[7] = NULL
serialData[8] = 555555
What the heck am I doing wrong? Why is it incrementing twice?!?
Thank you!
// State machine values
int state =0;
byte serialData[6][6] = {0};
//serial data
byte serialChar =0;
boolean newData =0;
byte i2 = 0;
  Serial.println("Serial 1 Good Morning");
  Serial1.begin(115200);
  Serial1.println("Serial 2 Good Morning");
          if (Serial1.available() > 42) {
            newData = true;
            Serial.write("***** BEGIN DATA state = ");
            if (state == 0){
              for(i=0;i<43;i++)
                serialChar = Serial1.read();
                if (serialChar == 32){
                  state = 1;
                  serialProcess(state);
          delay(250);
  if (newData){
    Serial.write("{t1:");
    Serial.print(serialData[0]);
    Serial.write(",t2:");
    Serial.print(serialData[1]);
    Serial.write(",t3:");
    Serial.print(serialData[2]);
    Serial.write(",lat:");
    Serial.print(serialData[3]);
    Serial.write(",lon:");
    Serial.print(serialData[4]);
    Serial.write(",rpm:");
    Serial.print(serialData[5]);
    Serial.write("}");
    Serial.println("");
    newData =false;
void serialProcess(int st){
      Serial.println("");
      Serial.print("State of: ");
      Serial.println(state);
      for (byte i=0; i<7; i++) {
                if ((serialChar > 65) && (serialChar < 71)){
                  if (serialChar == 66){state = 2;}
                  if (serialChar == 67){state = 3;}
                  if (serialChar == 68){state = 4;}
                  if (serialChar == 69){state = 5;}
                  if (serialChar == 70){state = 6;}
                  i2=0;
                else if ((serialChar != 32) && (serialChar !=255))
					Serial.print("Echoing State before print state: ");
					Serial.print("Char: ");
					Serial.write(serialChar);
                    Serial.print("");
                    serialData[(state-1)][i2] = serialChar;
                    i2++;
                else if (serialChar == 13){
                  i2=0;
                  state=0;
                  Serial.println("");
                  Serial.println("***END OF DATA***");
Moderator edit: [code] ... [/code] tags added to debug output. (Nick Gammon)
    newData = true;
    if (state == 0){
      for(i=0;i<43;i++)
          state = 1;
If you have more than 42 bytes of serial data you are reading it 43 times.
  Serial.println("");
Then you are reading another 7.
What's with all the numbers? Why not:
      if (serialChar == 'B'){
Maybe read this:
Make that:
        if (serialChar == ' '){
Readable code is nice.
Dang, I knew there was a way to get the code to interpret the data for you. I will use the ' ' for sure.
With regard to the looping 42 times, I have a break when it detects my "start" char, basically a way to ensure that I am starting at a known point, I realize now though that since I am reading through the data with different letters to index, I can really start anywhere one of those chars exist. Thanks for the pointer there.
    if (state == 0){
      for(i=0;i<43;i++)
          state = 1;
Anyway, I am still having the problem here
                    Serial.print("");
                    i2++;
This line
Is supposed to put the currently read char at the [state-1][increment] of the char array, but for some reason [state] is doing weird things and data is only getting stored in the 0,2,4 arrays of the the first dimension.
When I do
I get matching states with the data they belong to.
With respect, your code is very confusing.
I suggest you read the linked page (http://www.gammon.com.au/serial) and see simpler ways of parsing incoming serial data.
No offense taken. Reading it now, I will try to make it more understandable before resubmitting.
does not seem to be very close to a compilable statement...
